Golf mk2
crankshaft removal how easy is it
Topic: crankshaft removal how easy is it (Read 1658 times)
oakgreengolf
CAR FOR SALE PM FOR FURTHER INFO
23 October 2011, 10:06 »
Need to remove this is it pretty straight forward is there a step by step guide anywhere. I imagine I need to remove Cambelt, head is comming off anyway. Undo sump bolts remove oil pump. Then I'm not sure never done this side of engine before. It's the abf engine. any help appreciated.
Last Edit: 23 October 2011, 10:16 by oakgreengolf
The Mighty Elvi
I'm better than you today.
Re: crankshaft removal how easy is it
23 October 2011, 10:26 »
Engine in or out of the car?
The Mighty Elvi
23 October 2011, 10:30 »
Watch all this guys videos.
very useful to know. Should give you a great understanding in removing the crankshaft, all be it in reverse.
http://www.youtube.com/user/9Barry009#p/c/BAA75E641EC59575/52/23MTtYGZEQ8
oakgreengolf
23 October 2011, 11:15 »
Engine is I'm the car so I can do it from underneath.
pigbladder
GTI forum regular
23 October 2011, 11:39 »
gearbox and flywheel off , sump n all that then just unbolt it all , mark all the caps and take note of where they came from and what way round they went
AudiA8Quattro
Forum addict
23 October 2011, 15:42 »
Would it not be much better to remove the engine to do this?
oakgreengolf
Reply #6 on:
23 October 2011, 16:11 »
I've got a 6 ft pit underneath the car so access isn't a problem. Just to confirm the gearbox has to cone off. Do I need to remove the bottom pulley or is that separate.
danny_p
Forum addict
Reply #7 on:
23 October 2011, 21:22 »
everything var crank out you can do engine in.
removeing crank with engine in is a pita, putting the cranck back in with the engine in car is a twit, quicker and easyer to take engine out.
all the VW's have gone bar 1.
DOA
Reply #8 on:
24 October 2011, 22:26 »
You must be a glutton for punishment trying that in a pit, my arms, neck and shoulders are aching just thinking about it. Take the advise and pull the engine
Golf mk2
