Author Topic: Fabia vRS - ABS/Electrical Problems  (Read 5071 times)
Offline Yohan
« on: 22 October 2011, 19:15 »
Evening,
Took my Fabia out for a spin today as it hadn't been used for the past week and it seems to have developed a few problems whilst sitting around doing nothing.
Symptoms
    First turned it on and a warning light with steering wheels and ! showed up
    When driving it the hand brake light, ABS light, and TCS light, randomly flash up and the speedo drops to 0mph before bouncing back up to whatever speed I'm travelling.
    Steering wheel feels really light when on the move i.e. 60mph and really heavy when moving at slow speeds, seems more noticable when turning right.
Video
Took a video of what it does, apologies for the crap quality but it's all I had with me at the time. The fault happens near the end of the video.
Vag-Com Log
Ross-Tech wiki wasn't too helpful this time.
Saturday,22,October,2011,18:51:56:62534
VCDS Version: Release 10.6.5
Data version: 20110930
Chassis Type: 6Y - Skoda Fabia I
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56 76
VIN:    Mileage: 162920km/101233miles
Address 01: Engine        Labels: 038-906-019-ASZ.lbl
   Part No: 038 906 019 NF
   Component: 1,9l R4 EDC 0000SG  5839
   Coding: 00102
   Shop #: WSC 13765
   VCID: 68DA2CC922E8
   TMBWU46Y954201611     SKZ7Z0D2629352
1 Fault Found:
18057 - Powertrain Data Bus: Missing Message from ABS Controller
            P1649 - 35-10 -  -  - Intermittent
Readiness: 0 0 0 0 1
Address 03: ABS Brakes        Labels: 6Q0-907-37x-ASR.lbl
   Part No SW: 6Q0 907 379 AB    HW: 6Q0 907 379 AB
   Component: MABS 8.0 front  H03 0001
   Revision: 00000000    Serial number: 00000000000000
   Coding: 0000008
   Shop #: WSC 13765 000 00000
   VCID: 7DF46D9D5D6A
1 Fault Found:
01314 - Engine Control Module
            013 - Check DTC Memory - Intermittent
             Freeze Frame:
                    Fault Status: 00101101
                    Fault Priority: 2
                    Fault Frequency: 7
                    Reset counter: 31
                    Mileage: 162907 km
                    Time Indication: 0
Address 08: Auto HVAC        Labels: 6Q0-820-045.lbl
   Part No: 6Y0 820 045
   Component: Klimaanlage        X0840
   VCID: F2EECEA19434
1 Fault Found:
01271 - Positioning Motor for Temperature Flap (V68)
            29-10 - Short to Ground - Intermittent
Address 09: Cent. Elect.        Labels: 6Qx-937-049-C.lbl
   Part No: 6Q1 937 049 D
   Component: 0000 BN-SG.         1S34
   Coding: 25754
   Shop #: WSC 13765
   VCID: 3C72A09906F0
1 Fault Found:
01316 - ABS Control Module
            49-00 - No Communications
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 1C0 909 601 A
   Component: 11 AIRBAG VW51      0008
   Coding: 12593
   Shop #: WSC 13765
   VCID: 1E364A11B02C
No fault code found.
Address 17: Instruments        Labels: 6Y0-920-xx0-17.lbl
   Part No: 6Y0 920 971 S
   Component: KOMBI+WEGFAHRSP VDO V02
   Coding: 28401
   Shop #: WSC 13765
   VCID: 4E96FA51A04C
1 Fault Found:
            49-10 - No Communications - Intermittent
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: 003D GATEWAY CAN    1S34
   Coding: 00014
   Shop #: WSC 13765
   VCID: F0EAC4A99A38
1 Fault Found:
Address 44: Steering Assist        Labels: 6Q0-423-156.lbl
   Part No: 6Q0 423 156 AB
   Component: LenkhilfeTRW        V270
   Coding: 10120
   Shop #: WSC 13765
   VCID: 6FE847D50706
Address 46: Central Conv.        Labels: 6Q0-959-433.lbl
   Part No: 6Q0 959 433 E
   Component: 2Y Komfortgerát     0002
   Coding: 00066
   Shop #: WSC 13765
   VCID: 3D74AD9D1DEA
   Part No: Steuerger
   Component: t Fahr. antwortet nicht
   Part No: Steuerger
   Component: t Beif. antwortet nicht
End   ---------------------------------------------------------------------
Thanks in advance [:)]
Yohan
Offline Yohan
Re: Fabia vRS - ABS/Electrical Problems
« Reply #1 on: 23 October 2011, 12:56 »
Right only managed to clean the 3 earths on the strut and check the ECU plugs/contacts before rain put an end to any further investigation.
The fuses on the battery are all ok.
Cleared all codes with vag-com and I've got a new one now in the engine module.
Sunday,23,October,2011,12:47:20:62534
VIN: Mileage: 162930km/101240miles
Coding: 00102
Shop #: WSC 13765
VCID: 68DA2CC922E8
2 Faults Found:
18061 - Please check DTC Memory of ABS Controller
P1653 - 35-00 - -
Readiness: 1 1 1 1 1
Coding: 0000008
VCID: 7DF46D9D5D6A
VCID: F2EECEA19434
Coding: 25754
Shop #: WSC 13765
VCID: 3C72A09906F0
1 Fault Found:
Coding: 12593
Shop #: WSC 13765
VCID: 1E364A11B02C
Coding: 28401
Shop #: WSC 13765
VCID: 4E96FA51A04C
1 Fault Found:
Coding: 00014
Shop #: WSC 13765
VCID: F0EAC4A99A38
1 Fault Found:
Coding: 10120
Shop #: WSC 13765
VCID: 6FE847D50706
Coding: 00066
Shop #: WSC 13765
VCID: 3D74AD9D1DEA
Part No: Steuerger
Part No: Steuerger
Should I start pricing up ABS controllers?
Offline Rhyso
« Reply #2 on: 23 October 2011, 13:16 »
Have you checked the fuse for the ABS? Can you communicate with the controller at all?
Offline Yohan
« Reply #3 on: 23 October 2011, 13:29 »
Assuming there is just the fuse on the battery then yeah they are all ok.
I can communicate with it through vag-com and clear faults on it or go to measuring blocks. Just seems to happen every few seconds when driving.
Offline Rhyso
« Reply #4 on: 23 October 2011, 13:44 »
Think there is one under the dashboard too but if that was shot you wouldn't be able to communicate with the controller
How far did you drive the car as the system is self checking.  Perhaps the fact its sat still for so long it needs to be driven to get the voltage back up in the battery and for the system to be happy  :undecided:
Offline Yohan
« Reply #5 on: 24 October 2011, 08:40 »
Well what ever the fault is, it's permanent now. Speedo didn't work from the word go this morning and also when I turn corners or brake harshly the fuel gauge drops to zero then back up to what it actually reads (3/4 full), this also causing the low fuel light to briefly appear on the dash.
I'll take all the fuses off today and have a proper look.
