Author Topic: waht is the correct offset for a mk3 on the floor  (Read 1424 times)
Offline dubpirate
« on: 22 October 2011, 09:08 »
im going as low as i can
coilovers
wanting sum 15s
whats the best wheels size and ofsett to allow the drop easily
wheel width tyre stretch spacers let me know what ur doing to get them so low
cheers dan
Offline Gash
Re: waht is the correct offset for a mk3 on the floor
« Reply #1 on: 22 October 2011, 10:48 »
Well I'm running 16 x 7j down about 145mm 195/40 tyres, et32, 30mm spacers and no rubbing :)
Offline mush
« Reply #2 on: 22 October 2011, 11:36 »
i'm down 100mm with standards and with 3 big dudes in the back no scrubage so may go lower
MK2 golf 16v :-)
« Reply #3 on: 22 October 2011, 21:51 »
Et30 or 35 with a 100mm drop.
Offline tweed
« Reply #4 on: 22 October 2011, 23:56 »
When I dropped mine down on standard wheels and 205/50/15 tyres I found that the rear driver rubbed the fuel tank  :shocked:
Fit a 5mm spacer  :wink:
Offline dubpirate
« Reply #5 on: 24 October 2011, 17:53 »
what do we recon to et 40 cheers guys 6 inch rim
« Reply #6 on: 24 October 2011, 21:12 »
Will be a long way in and could look lost.
Offline Malz0r
  • Haters gunna hate.
« Reply #7 on: 25 October 2011, 14:33 »
I'm running a 7.5 inch ET20 on the rear of mine it it rubs all the time even empty! I used o run a set of Audi wheels on a 7.5 and ET was 32 or something? Either way try cleared easy!
