Author Topic: leaks  (Read 1615 times)
Offline briwyle
leaks
« on: 28 April 2005, 20:37 »
found a pool of water on the passenger side footwell of my golf cab this morning but cant figure out where its come from there are no wet patches anywhere else and i deffinately know my roof dont leak cus i just fitted a new header seal.   can anyone think of anything
cheers
mark
mix
Re: leaks
« Reply #1 on: 28 April 2005, 21:10 »
Try your door seals, have you checked the bottom of the door crads????
Dinky
Re: leaks
« Reply #2 on: 28 April 2005, 21:11 »
this mite sound stupid,but is your car parked on a slant? its just mine was n when it was raining,the water was building up where the drainage holes r,and with them being blocked with loadsa sh!te,the water had no where to go bar this other hole that only had a couple of wires goin through it,into my footwell.
Also,there r a couple of threads about this in this section...mite b worth lookin up?
hope this makes sense?  :laugh:
Dinx :kiss:
Offline briwyle
Re: leaks
« Reply #3 on: 28 April 2005, 21:15 »
no not on a slant, not sure where those drainage holes are either, but i have noticed alot of water on the door sills when i open them
Dinky
Re: leaks
« Reply #4 on: 28 April 2005, 21:17 »
your drainage holes r under your bonnet,at the very top where you have that plastic covering..like just down from your wipers,but under the bonnet..
if its on ur sills,like mix said try ur door rubbers..
Dinx :kiss:
mix
Re: leaks
« Reply #5 on: 28 April 2005, 21:21 »
sounds like your rubbers split......
Try this for a way to sort it out.....
clicky here
Offline briwyle
Re: leaks
« Reply #6 on: 28 April 2005, 21:25 »
could it maybe something to do with the heater in the middle because the puddle is right by the gearstick???????
mix
Re: leaks
« Reply #7 on: 28 April 2005, 22:25 »
could be your matrix is gone then.....not to sure tho
