Author Topic: Coilover setup advice  (Read 1174 times)
Offline 67buggers
« on: 20 October 2011, 21:10 »
Right just brought and fitted some hot tuning coil overs.....cheap I know but I'm on a budget! They are set up at the minute with pretty much no compression on the springs and the car sits nice a low. I turned one front coil over adjuster all the way up and fully compressed the spring expecting my car to hit the deck but it ended up raising the ride height by about 40mm??? Is this right I thought it worked the other way?.....confused!
I fix iPhone's and iPod's, I can fix most faults call me on 07811344816 for a quote
Re: Coilover setup advice
« Reply #1 on: 20 October 2011, 21:28 »
Fail  :smiley: wind it down to lower it.
Offline 67buggers
« Reply #2 on: 20 October 2011, 21:52 »
Mint, so adjusters at the bottom/ lowest point means suspension set at it's lowest ? Probably sounds a stupid question!
Offline dom
  • Back in a Mk4
« Reply #3 on: 20 October 2011, 22:12 »
 :grin: :grin:
Offline boneybradley
  • Back in a Mk3...
« Reply #4 on: 20 October 2011, 23:02 »
b.t.w it will settle in a week or two (mine went another 15mm lower!) take that into account unless you fancy adjusting them again soon!
Offline 67buggers
« Reply #5 on: 21 October 2011, 06:30 »
The lower the better in my opinion  :smiley: thanks guys ....I'm a bit of a biffa with all this kinda stuff
« Reply #6 on: 21 October 2011, 08:05 »
I would set them about half way to start with, then run it for a couple of weeks, let it settle then tweak as required.
