Author Topic: sensors  (Read 1487 times)
Offline Egg On Toast
sensors
« on: 20 October 2011, 19:14 »
My car has the symptoms of either the fuel pump sensor, or the crank speed sensor being faulty, so i'd like to change these.
anyone got a good how to, or can tell me how simplistic these jobs are?
Thanks
also, where do I get some at a good rate?
Offline Seanl
Re: sensors
« Reply #1 on: 20 October 2011, 21:14 »
What car and what are the symptoms?
Re: sensors
« Reply #2 on: 20 October 2011, 23:50 »
Best way to describe it is like it sometimes runs like its just about to run out of fuel
Offline javalin
Re: sensors
« Reply #3 on: 21 October 2011, 09:59 »
the mk3 doesn't have a fuel pump sensor.  Can you describe the symptoms better - could be many things.  Does it do it when hot / cold?  Cuts out at idle?  Lumpy idle? etc?  Under load/ off load?
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Re: sensors
« Reply #4 on: 21 October 2011, 18:44 »
sorry to be vague, been using my phone.
Anyway,
it judders badly, only occasionally is it like it though, struggles for power, the rev counter still goes up, but you can tell quite clearly you aren't doing the speed it says you are. I only tend to drive with myself in the car. has a few flat spots across the rev counter.
It does idle a little rough, but nothing major
it's a MK3 8v GTI btw
Re: sensors
« Reply #5 on: 21 October 2011, 19:05 »
Might be worth cleaning the throttle body 1st.
Also unplug the maf and see if it runs better.
Re: sensors
« Reply #6 on: 22 October 2011, 11:33 »
I unplugged the MAF and it just idled like a bag of carp. What's the best thing to clean my throttle body with matey?
Offline mush
Re: sensors
« Reply #7 on: 22 October 2011, 11:58 »
http://www.gsfcarparts.com/
this is a good place and decent on price.
had a few sensors from them in the past and been fine.
MK2 golf 16v :-)
Offline Screech16v
  • MK3 20vt AGU
Re: sensors
« Reply #8 on: 23 October 2011, 13:03 »
Have you tried replacing relays 30 and 167?
Re: sensors
« Reply #9 on: 25 October 2011, 22:11 »
I might just replace all the commonly faulty parts tbh. elminates any potential problems then!
