Author Topic: Fuel Pump Relay gone?  (Read 2801 times)
Offline Gabriel2202
« on: 20 October 2011, 16:07 »
I have had these fault codes on vagcom and when i delete them they show up again straight away before ive run the engine again!! :huh:
as they're all short to ground does this indicate an electrical fault? possibly fuel pump relay? as the choke is always on when first starting up even on the hottest days.... and sits at 1200rpm for a few minutes...
here are the codes i get:
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
            P1297 - 35-00 - -
17633 - Fuel Injector for Cylinder 1 (N30): Short to Ground
            P1225 - 35-10 - - - Intermittent
17635 - Fuel Injector for Cylinder 3 (N32): Short to Ground
            P1227 - 35-10 - - - Intermittent
17636 - Fuel Injector for Cylinder 4 (N33): Short to Ground
            P1228 - 35-10 - - - Intermittent
17634 - Fuel Injector for Cylinder 2 (N31): Short to Ground
            P1226 - 35-10 - - - Intermittent
17833 - EVAP Purge Valve (N80): Short to Ground
            P1425 - 35-10 - - - Intermittent
17955 - Boost Pressure Regulation Valve (N75): Short to Ground
            P1547 - 35-10 - - - Intermittent
17525 - Oxygen (Lambda) Sensor Heating Circuit: B1 S2: Short to Ground
            P1117 - 35-10 - - - Intermittent
17843 - Secondary Air Pump Relay (J299): Short to Ground
            P1435 - 35-10 - - - Intermittent
17938 - Camshshaft Timing Adjustment: Short to Ground
            P1530 - 35-10 - - - Intermittent
17829 - Secondary Air Injection Solenoid Valve (N112): Short to Ground
            P1421 - 35-10 - - - Intermittent
17697 - Boost Pressure Control Valve (N249): Short to Ground
            P1289 - 35-10 - - - Intermittent
thanks in advance for your help
Golf IV 1.8T AUM
Golf V GT TDI PD170
Offline javalin
Re: Fuel Pump Relay gone?
« Reply #1 on: 21 October 2011, 11:53 »
I would say so.
What car is it?
Are all these components on the same loom?  Possible multiple looms are damaged of course.
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline Gabriel2202
« Reply #2 on: 22 October 2011, 19:59 »
I would say so.
What car is it?
James
thanks for the reply  :smiley: Its an x reg 1.8t aum engine. How can i see if theyre on the same loom?
Golf IV 1.8T AUM
Golf V GT TDI PD170
Offline Chris.
« Reply #3 on: 22 October 2011, 20:02 »
Looks like a grounding issue to me!
Check the leads from the negative battery (even the one under the battery) and to the engine.
Worst comes to worst, get a nice 4awg wire and create a new ground and see what that does.
Click For Build Thread
Offline Gabriel2202
« Reply #4 on: 23 October 2011, 08:20 »
hmm, looks like im going to have to do some studying as im not at all clued up on electrics... whats a 4awg wire?
Golf IV 1.8T AUM
Golf V GT TDI PD170
Offline Chris.
« Reply #5 on: 23 October 2011, 10:56 »
Thickness of the wire!
