Author Topic: mk2 shocks/springs on a mk3  (Read 1504 times)
Offline Diluxe
« on: 20 October 2011, 05:40 »
I had a low mileage eibach/koni setup from my old mk2 16v that I scrapped, the old dears mk3 cl needs new shocks up front , i know the springs rate etc will be different but what do I need  to allow me to use my mk2 stuff?
1997 16V
Re: mk2 shocks/springs on a mk3
« Reply #1 on: 20 October 2011, 14:00 »
I think all you need to do is change the front top mounts and spring plates.
Offline Diluxe
« Reply #2 on: 20 October 2011, 14:02 »
is the spring plate the one that stops the shock falling through or coming up ?
1997 16V
« Reply #3 on: 20 October 2011, 14:04 »
the top spring plate  :smiley:
« Last Edit: 07 December 2011, 16:39 by Wayne »
Offline mark-mk3gti
« Reply #4 on: 20 October 2011, 22:41 »
Yeah you  just need early mk3 top spring plates, slotted nut, washer, and top mount, which is same as mk2, as I did this recently and used g60 top mounts.. :)
Offline boneybradley
  • Back in a Mk3...
« Reply #5 on: 20 October 2011, 22:58 »
if the mk3 is pre mid 95 then it will use the same top plates and mounts (it's the pig tail that changed, I think later are 65mm and early mk3/mk2 are 80mm)
Offline Diluxe
« Reply #6 on: 21 October 2011, 00:35 »
so the motor is an R reg which is 1997 so this is defo the mk3 stuff right?
1997 16V
  • Back in a Mk3...
« Reply #7 on: 21 October 2011, 08:38 »
later type with the smaller sping plates...new plates (a few ££ from gsf/ecp or even vw) and top mounts will be ok (although while it's off I would swap them for new one's from a vr6)
Offline Diluxe
« Reply #8 on: 21 October 2011, 08:41 »
cheers buddy, will I need spring clamps?
1997 16V
