Author Topic: question fo rnick for mk1 remap  (Read 1933 times)
Offline lord14
« on: 19 October 2011, 17:17 »
since the last time we tried to get it mapped , ive had the engine out and sorted everythink out all the boost leakes , new turbo , new cone filter , seems to be running alot better , was just wondering whats best to do about the throttle body problem  as i cant find any agu ones for sale , and have tried cleaning it . is the mapp on the car now ok or does it still need tweeking ?  thanks rob :
Offline RTechUK
  • R-TECH OFFICE 01455 617233
Re: question fo rnick for mk1 remap
« Reply #1 on: 19 October 2011, 18:00 »
The TPS needs to be working, 100% if not the map axis that relate to the throttle postion wont be correct, You need to find a good throttle body and make sure its adapting.  It might be worth checking the pinouts on the loom to make sure its the TB not an electrical fault.
 01455 617233
Offline lord14
« Reply #2 on: 19 October 2011, 18:06 »
already checked the pin outs defonately wire up theres live when the ignition is on , and its controlled direct from the ecu according to the vw wiring diagrams , how do i check if its adapting is there a way of doing it
