Author Topic: finally started my abf conversion:-)  (Read 40828 times)
Offline mk2addict
Re: finally started my abf conversion:-)
« Reply #50 on: 05 December 2011, 21:43 »
got the engine started strippin cleaing and painting it also ordered my corrado pedal box and got a decat pipe and the abf loom should come this week so should get all those in this ween not the engine i mean pedal box and loom, i want a 4 branch manifold for it ive seen one on ebay for a mk3 will that fit? also any advice on the loom will be good hopefully itll plub straight into the fuse box?
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #51 on: 05 December 2011, 23:14 »
From what I've read you need a tsr tall block manifold as the mk3 one hits the chassis could probably solve with a bit of hammering but I'm saving for a tsr one..
Offline SoundillusioN
« Reply #52 on: 06 December 2011, 00:05 »
I've read similar somewhere....
I think you can leave your fusebox in with your lighting looms in etc and just swap out the engine looms.
Offline mk2addict
« Reply #53 on: 06 December 2011, 08:17 »
Yea had a look on tsr last night 300 smackers tho, but if it fits right its all good, that's what I'm hopein loom straight out and in but probs won't be that easy.
Offline lemski
  • 16v
« Reply #54 on: 06 December 2011, 08:26 »
Its only slight modifications to the loom I think. Mostly plug an play though
Offline mk2addict
« Reply #55 on: 06 December 2011, 09:31 »
What kinda slight modification?lol
Offline lemski
  • 16v
« Reply #56 on: 06 December 2011, 12:31 »
That I don't know. Just know about ecu needs deimobalIzing. Loom stuff am not sure
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #57 on: 06 December 2011, 20:18 »
either need to carry ecu, loom, immobiliser and chip.. or just ecu and loom and delete the immob on ecu for about £55-60..
I got my loom done by a member on here for £100 so it was the right length to reach the places it needs to and was done properly as wiring can be tedious.. all you need is ABF engine loom and mk2 lighting loom as mk3 one wont fit iirc..
Offline mk2addict
« Reply #58 on: 06 December 2011, 21:38 »
I have ecu transponder key and immobiliser:-) and abf loom on the pedal box should be here by the weekend so a lot is gunna happen this week
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #59 on: 06 December 2011, 21:55 »
yer so all you need to keep is the mk2 lighting loom.. The mk3 ecu wires need lengthening aswell iirc to fit in the standard mk2 place and a seat cradle as mk2 and mk3 one dont fit
