Author Topic: finally started my abf conversion:-)  (Read 41001 times)
Offline lemski
  • 16v
Re: finally started my abf conversion:-)
« Reply #40 on: 23 November 2011, 08:55 »
is it a carrado pedal box you got or just a mk3 pedal box?
Offline mk2addict
« Reply #41 on: 23 November 2011, 17:49 »
Just a mk3 pedal box with hydrolic clutch it'll fit won't it?
Offline leeroy20vt
  • h reg mk2 gti
« Reply #42 on: 23 November 2011, 21:35 »
i dont think it will m8 tbh
Offline mk2addict
« Reply #43 on: 23 November 2011, 23:28 »
Y not? I think it does I'll see when it comes if not ill stick wiv the rod shift box and 020 box
Offline Neo Badness
  • Feet are for pedals
« Reply #44 on: 23 November 2011, 23:56 »
Ah, yes I can't remember why but I don't think it will fit. You could always try and prove us all wrong but I think you'll need either a corrado/ passat or maybe a SEAT setup?
Depends what you want, I've opted to bypass the ballache of hydro and bleeding clutches by getting a SEAT setup. Bolt on bit means you can keep your pedal box, but run hydro box but use a cable actuator. :cool:
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #45 on: 24 November 2011, 00:02 »
+1 on this, this is how im going just need to source cable clutch parts  :wink:
Offline lemski
  • 16v
« Reply #46 on: 24 November 2011, 09:03 »
Avgot the carrado pedal box that am usin wen i find my new g/b
Offline leeroy20vt
  • h reg mk2 gti
« Reply #47 on: 24 November 2011, 18:06 »
from memory u can make them fit but its not that easy as every one else has said go for the corrado /passat/seat
all i done in mine was used a mk3 8v box so all rod change and easy to fit clutch cable and running the lighter 8v flywheel
Offline mk2addict
« Reply #48 on: 24 November 2011, 21:44 »
Ok cool the guy I bought the engine off has just said the pedal box is no good so which pedal box is best to go for?
Offline lemski
  • 16v
« Reply #49 on: 24 November 2011, 22:19 »
Carrodo or passat if your keepin hydro setup
