Author Topic: What's this connector called?  (Read 1828 times)
Offline Steve_B
« on: 17 October 2011, 20:07 »
Have got a beesting aerial i want to replace the current one but need to get some cable to connect it. My question is what's the name of this connector, am then hoping to be able to search for some aerial cable with the right connector.
Connector pictured has thread on the outside.
Re: What's this connector called?
« Reply #1 on: 17 October 2011, 23:45 »
Not sure on name but you can get adaptors to convert to a standard cable.
Offline Steve_B
« Reply #2 on: 18 October 2011, 10:24 »
Yeah, guess i'll just have to take it to a car audio shop.
Offline Pluginz
« Reply #3 on: 18 October 2011, 19:38 »
There happens to be a few of those connectors behind the fusebox that you dont need.  Dim dip resistor wiring.  Splits off from headlights. Yellow wire
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #4 on: 18 October 2011, 20:23 »
That cable is the aerial cable that goes into the back of the radio.  You have an a socket for an extension co-ax cable rather that the normal one of these:
http://www.ebay.co.uk/itm/VW-GOLF-MK2-GTI-REAR-ROOF-AERIAL-AND-CABLE-/170669605421#ht_500wt_1287
Just get some co-ax cable.
