Author Topic: Best way to more reliable horses?  (Read 1632 times)
Offline jasontrue
« on: 27 April 2005, 22:26 »
Hello there. I might be buying a mk1 gti with about 140kish on the clock. What would be the ideal way to bump up the power? Would a rebuild with some cams and a chip do well? Transplant for something mental would be the most desirable choice but i'm a student with budget of about a grandish. I don't know a lot about golfs. Thanks in advance  :grin:
Offline gibby
Re: Best way to more reliable horses?
« Reply #1 on: 28 April 2005, 08:16 »
The options are endless and all dependant on how many dollars you have to throw at it. The first thing to do would be to give it a good service, get a decent exhaust and a panel filter and this will give you a bit more oomph, but don't expect miracles. Then you could go for uprated cams etc etc, but this will all add up in price and will not be cheap. The other route is the engine transplant, 20vt is probably the best option  :grin: but will cost some coin to put in, a more affordable transplant is a 16v conversion as this will be your cheapest option and a mk2 16v in a mk1 would make it fairly rapid seeing as the mk1 only weighs about 840kg. You can't chip a mk1 k-jet engine by the way. These questions have been asked a few times so have a search round the site and see what you can find.  :smiley:
......now officially dubless.
Offline jasontrue
« Reply #2 on: 28 April 2005, 11:11 »
Who are the main tuners in the uk? Are there any ones worth mentionning in Essex?
Offline sportline_velly
  • Quick hairdressers car...you knows it
« Reply #3 on: 28 April 2005, 11:29 »
imo the best and cheapest way is one of the following
1- change the bottomend for a 2.0   (bags of torque)
2- fit a 1.8 16v lump
3- fit a 2.0 16v lump
prob the 1st one out be the simplest  :cool:
Velly
16v Sportline 145bhp/135lb.....its all about the torque!
ClubGTI Newport Regional Host
Offline gibby
« Reply #4 on: 28 April 2005, 12:07 »
Have a look at the main site page ----> http://www.golfgti.co.uk/ at the bottom there is a load of useful links, take a wander round there as I don't know Essex I'm afraid, too far south ! :wink:
Offline benmk1
« Reply #5 on: 02 May 2005, 16:03 »
Or cheaper an easier way is to rebuild the block to 1900cc, less problem with breather hoses, etc. Get a cam,do some gentle homemade head polishing, stainless exhaust and manifold, 16v warm up reg and an audi throttle body. Sould be a bit of a stonker then
I don't look at porn much,
usually 2 or 3 minutes is enough
Offline black_cabbie
  • If they don't have a golf in heaven I am not going
« Reply #6 on: 05 May 2005, 12:30 »
How deep are your pockets?  :grin:
1.8L 8V Digifart, AMS chip, Kent 270 camshaft, TT Adjustable Cam Gear, Supersprint Header with supersprint catless system, BMW AFM, Adjustable FPR. G60 Green 23lb injectors coming soon.... =)
« Reply #7 on: 05 May 2005, 12:39 »
that really is the bottom line  :grin:
Velly
