Author Topic: Clutch pedal sticking to the floor  (Read 2525 times)
Offline GTGirl
« on: 17 October 2011, 09:27 »
Hey guys
I seem to have a problem with my clutch pedal, This morning the clutch pedal was stuck to the floor and the car wouldn't go into gear.. After lifting the pedal up manually it worked fine.. This has happened twice now in a couple of weeks... Also the clutch has felt almost sloppy lately.. This morning is a cold one, but the last time this happened it wasnt, so i am not lead to believe this is down to the temperature outside.. It has also recently been serviced and had a fluid change.
Is this likely to be a major problem?
Thanks
L x
Offline Adam
Re: Clutch pedal sticking to the floor
« Reply #1 on: 17 October 2011, 11:44 »
Check your brake fluid level and condition of the fluid.
Down Hill From Here.
Offline GTGirl
« Reply #2 on: 17 October 2011, 12:00 »
It was only serviced a couple of weeks ago and had a brake fluid change, so i am sure the condition is fine! Just to see if the levels have gone down, as from what i have been reading it could be the Master or Slave cylinder needing replacing..  :sad:
Sounds like my bank balance will be taking a nose dive!
Thanks  :smiley:
