Author Topic: 02A Starter motor help please  (Read 1511 times)
Offline Gloves88
« on: 16 October 2011, 20:23 »
I have a Diesel ASD 02A gearbox on a mk4 20vt engine.
Will any 02A starter fit? Or are the diesel and petrol gearboxes different?
Offline Dan_GTi8v
Re: 02A Starter motor help please
« Reply #1 on: 16 October 2011, 20:49 »
Pretty sure they are the same but I'm sure someone will confirm shortly
Offline Gloves88
« Reply #2 on: 18 October 2011, 07:52 »
Thanks Dan.
Can anyone confirm? 02A gearbox knowledge seems to be a bit of a dark art  :smiley:
Offline Dan_GTi8v
« Reply #3 on: 18 October 2011, 14:07 »
I thought someone would of answered this by now its usually pretty good in here :P
I have the DPA box on my 20vt which was using what I think iwas a 16v starter, had a search and couldn't find much but I found this which might be useful
Quote
the starter I took appart is a diesel starter, gasser should be the same. They are interchangealbe but a gas starter on a diesel will prolly die soon after as they are not designed for such high compression engines.
The best upgrade you can do to a gasser is swap the entire gas starter for a diesel starter. They are much more powerful but they weight a TON, which might offset it's advantages.
I did replace my starter not long ago and the new one I got from ecp when I asked for a 16v mk3 one did look different to the one I replaced, new one was a Lucas one (the more expensive one they do)
It looked like this, the pic is the diesel starter from the same thread I got the quote from and as it looks the same as my new 16v so I'd guess they are all the same?
Hope this helps in some way :P
