Author Topic: Distributor cap keep burning up :)  (Read 3164 times)
Offline Bigdunc
« on: 16 October 2011, 17:25 »
hi guys im finding that the Dizzy cap and rotor arm contact centre one keeps burning out, rotor arm i can clean up quite well but the centre on the dizzy cap wont clean up, now this keeps doing it every few thousand miles if that im having to change them.
what could be the cause of this??
Offline the flying mantuan
Re: Distributor cap keep burning up :)
« Reply #1 on: 16 October 2011, 19:05 »
When did you last gap the plugs?  :smiley:
Offline Bigdunc
« Reply #2 on: 16 October 2011, 19:39 »
never have i just replace plugs for new ones usually
« Reply #3 on: 16 October 2011, 20:14 »
Too large a gap can cause the HT system to operate at a higher voltage, leading to problems over time - in some cases burning out the rotor which in turn leads to the cap burning out. So that is the first thing I would check.  Then ignition timing and the engine (cambelt) timing. I also always,whenever possible, make sure the rotor arm and dizzy cap are made by the same manufacturer. It reduces the likelihood of the rotor arm being out of phase with cap.
Offline Bigdunc
« Reply #4 on: 16 October 2011, 23:08 »
well belt and dizzy timing are spot on as not long set the timeing with the light, plugs were changed under 400miles ago and rotor arm and cap changed at the same time, plugs were new ngk from the box and leads changed at same time, i cant get a plug gap tool but what gap should the plugs be at??
« Reply #5 on: 17 October 2011, 16:31 »
0.8mm according Haynes
I just use feeler gauges no other special tools required.
« Reply #6 on: 17 October 2011, 23:46 »
Try a new rotor arm :smiley:
Offline Bigdunc
« Reply #7 on: 18 October 2011, 18:45 »
i put on a new cap, put my old leads back on as noticed new leads were sh!t connection
im using ngk BP6ET plugs but was wondering about changing to bosch plugs
Offline raferackstraw
« Reply #8 on: 18 October 2011, 19:27 »
i read something on here by dannyp that said single electrode plugs gave a better flame front and therefore better burn of fuel, also he stated that the single plug would last longer than the triple ones, im sure he also recommended ngk plugs but cant remember the reasons why.
dannyp may reply soonest  :wink:
wayne gardner smokes one rothmans too many
500cc 2stroke bad for ya health
Offline Bigdunc
« Reply #9 on: 20 October 2011, 18:45 »
well plugs are cheap as chips for me so im not worried about price but i would need to know what plugs i was getting,
i got a 2nd hand distributor to go in the car as the car has never run great with the dizzy it has anyway so going to put 2nd hand dizzy in and get a new cap and arm for it, then change leads and plugs then i can be far off getting car running sweet again :)
