Author Topic: New turborev smic fitted  (Read 3579 times)
Offline james2
  • No scammers please.
« on: 15 October 2011, 17:38 »
It fitted well ,apart from oil in the old intercooler again.  :cry: i might get a catch can. The oil that came out filled a paint roller tray, you know the big ones you put paint in one side well it filled the bit were the paint goes  :shocked: They should put sump plugs on intercoolers.  :laugh:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline GJSEB79
Re: New turborev smic fitted
« Reply #1 on: 15 October 2011, 19:02 »
was this on a tdi james or petrol mate and did the bumper go on right an was there any modifycation needed for it to fit mate
Offline james2
« Reply #2 on: 15 October 2011, 19:19 »
1.8 petrol.No mods needed but i was pissed off my old intercooler never had the 10mm plug to block the hole in new one ,it didnt even have one on the old one.I made a alloy plate and gasket with black silcon and bolted it over the hole.Seem to hold the boost, touch wood.  :wink: Bumper was easy to remove and refit with 2 people.  :wink:
Offline GJSEB79
« Reply #3 on: 15 October 2011, 19:39 »
so your old doesnt have the sensor in it then as i am going to be putting this on a tdi but i bleive mine has got the sensor did you get any fault codes turn up on the dash or not also do you feel any diffrence with it mate
Offline james2
« Reply #4 on: 15 October 2011, 20:32 »
i think yours will have sensor, no i have no fault codes but my ignition amplifier is playing up .Iv ordered a new one ,picking up monday.So cant try it as its like running on 3 cylinders, but it was fine again today.But i took it easy incase it plays up again. :undecided:
Offline GJSEB79
« Reply #5 on: 15 October 2011, 20:57 »
did you have get any new pipes or did the old ones fit with just new clips mate, also james i dont suppose you no if a diesel has this amplifer do they cheers gordon :huh:
Offline james2
« Reply #6 on: 15 October 2011, 21:10 »
it fitted straight on ,i didnt use anything else.Your car if its diesel wont have a ignition amplifier as it dont have spark plugs. :wink:
pic: http://www.use.com/a4e7c553ce2c98a1297e?p=3#photo=3
« Last Edit: 15 October 2011, 21:11 by james2 »
Offline GJSEB79
« Reply #7 on: 15 October 2011, 21:17 »
oh yeh  :grin: right just waiting for mine to turn up going take loads of photos i just hope my fitting goes as well as yours did was they alot of oil did you have to take the light out to get to the top clip on intercooler
Offline james2
« Reply #8 on: 15 October 2011, 21:22 »
no left light in ,but took the cover off the back of it. :wink: mine a intercooler/oil cooler :grin:
« Last Edit: 15 October 2011, 21:25 by james2 »
Offline GJSEB79
« Reply #9 on: 15 October 2011, 21:25 »
right spot on these little tips will hopefully help me out when i fit mine where abouts you located james just in case i get stuck ha ha  :laugh:
