Author Topic: Front Suspension spring broken  (Read 1313 times)
Offline bmouthboyo
« on: 15 October 2011, 13:36 »
Hello all,
Just found that my FOS suspension spring has the top 2 inches snapped off. MY car is a 96 Mk3 Gti Anniversary Edition.  It drives OK but makes a bit of a noise if I turn the wheel full lock either way when not moving (vibrations in steering wheel and makes a kinda tension noise). Will need to be replaced.
My question is:
A) Can I just replace one sides spring?
B) Where would be the cheapest place to get this part? (2nd hand ones OK from fleabay?)
C) Would I have to replace the top mounts etc. at same time?
D) Is this fairly straight forward job? (undo 2 top bolts joining to hub, undo top bolt in engine bay and lower?)
To be honest the car has done 170000 and I hope to upgrade in year or so but need it to get through MOT.
Thanks
Offline mark-mk3gti
Re: Front Suspension spring broken
« Reply #1 on: 15 October 2011, 23:51 »
Hi mate
Ideally I'd replace as a pair from a handling point of view,  (my opinion) but if u just want it to get through mot and are getting rid in the near future a second hand spring would do.
Shouldn't need to change top mounts, but you will need spring compressors to change over otherwise it's gonna be very difficult,
I'm a novice but just fitted a lowering kit, reckon I could do one in 30-45 mins which is probably a bit slow..
Just try and mark on the strut where the bolts are to try and avoid havin to get camber set again...
Good luck!
« Reply #2 on: 16 October 2011, 00:18 »
A) Better to fit a pair
B) Ebay etc but make sure they are 100% GTI spec.
C) Yes it would be wise to fit new top mounts
D) Allow around 1 1/2 hours and you should be fine, maybe a little longer, you will need spring compressors
Offline dom
  • Back in a Mk4
« Reply #3 on: 16 October 2011, 17:13 »
Hello all,
My question is:
Thanks
As already said:
A) Replace all suspension parts in pairs.
B) eBay is ok, but I wouldn't buy 2nd hand tbh. As Wayne has mentioned ensure that they are for a Gti.
C) Yes replace the top mounts but make sure you get decent ones.
D) Reasonably easy job, I'd get the geometry checked once completed.
Offline bmouthboyo
« Reply #4 on: 17 October 2011, 14:01 »
Thanks for feedback guys. I'll replace just the broken spring as I'll be getting another motor soon anyway.
Is there a special tool for the top nut? I remember it Needing a spanner bunt it's countersunk into the dish thing
Offline CJA321
« Reply #5 on: 17 October 2011, 15:37 »
Just use a deep socket. half inch. gun it off if you have a gun. if not put  a pair of vice grips on he shocker. rough but gets it done.
