Author Topic: polished tube/pipe  (Read 1130 times)
Offline EsSeX dAn
polished tube/pipe
« on: 14 October 2011, 00:05 »
im after about 300mm of polished pipe suitable for the cooling system for my mk2. its got to be about 40mm diameter or slightly smaller. any ideas apart from the bay?
i think i love you.....
Offline Diamond Hell
  • Opinions я Us
Re: polished tube/pipe
« Reply #1 on: 14 October 2011, 00:41 »
Make sure you rough the ends of the pipes up, or the rubber/silicone hose you're using will blow off under pressure.
Went to the 'ring with someone with a 20VT Rallye who couldn't understand why his shiny boost pipes kept blowing off.  :grin:
Here, have some emery cloth, make the ends not-shiny: problem solved. :grin:
Offline LowlifeDubber
« Reply #2 on: 14 October 2011, 07:10 »
I found a hand swaging machine on site one day just chucked in a skip!Gave it a clean up and now all my polished boost/cooling pipes get a small swage on the end and it does the trick.
Anyway 300x38mm o/d with a barb on the end £15
http://www.viperperformance.co.uk/productsearch.php?xscId=9731&mat=&filter=38mm%20Outer%20Diameter
« Last Edit: 14 October 2011, 07:12 by LowlifeDubber »
