Author Topic: Temp gauge problem  (Read 1215 times)
Offline gtirobbie
Temp gauge problem
« on: 13 October 2011, 13:14 »
My golf seems to be taking along time to get up to temperature, it's a 25mile drive to my work and the needle still doesn't quite make it halfway on the gauge, if I put the air con/heater on it goes down even further, I've tried replacing the coolant temp sensor but it hasn't made any difference, also Its coming up with the fault code 16500. Any ideas what is causing this??
Offline harlemex
Re: Temp gauge problem
« Reply #1 on: 13 October 2011, 13:21 »
You need a new thermostat matey.  :kiss:
jamie16v
« Reply #2 on: 13 October 2011, 13:22 »
i just looked up the definition and it cam up with this..
Definition type  Definition
VOLKSWAGEN  Engine Coolant Temperature Circuit - Range/Performance Problem
i am unsure exactly what could be causing this.. try changing the thermostat? perhaps its stuck open?..
Offline gtirobbie
« Reply #3 on: 13 October 2011, 13:25 »
Ok cool, is this an easy fix on a 1.8t?
jamie16v
« Reply #4 on: 13 October 2011, 13:28 »
pretty much yeah!
Offline harlemex
« Reply #5 on: 13 October 2011, 13:31 »
I just did mine. Very fiddly. You need really small hands and thin fingers. Remove engine and inlet covers, drain coolant, two bolts on the flange next to the alternator but very restricted area. I used a quarter inch drive socket and universal joint to get to the bottom one. Replace stat and seal and your ready to put it back together.  :nerd:
Offline gtirobbie
« Reply #6 on: 13 October 2011, 13:33 »
Il give that a go at the weekend, thanks for that!
Offline richw911
