Author Topic: new to mk4's advice please  (Read 2252 times)
Offline midz16v
« on: 12 October 2011, 20:59 »
Hi ,
I've just bought a 110 gttdi,had to sort the headgasket all gone well.
The other day when i was on my way to work it went into limp mode and had no power.
After a couple of days it was happening all the time,so had a look and the black plastic pipe had come off the cooler.
Got it back on and went well until the nite.
Had a mate scan it and came up with 4 fault codes
17965
17563
17978
17655
Can anyone shed any light as to what these mean?moved over from mk2's so just learning about mk4's.
cheers
Offline daz veedub
  • Operation 1.8t bolf
Re: new to mk4's advice please
« Reply #1 on: 12 October 2011, 21:12 »
Hi ,
17965
17563
17978
17655
cheers
17563/P1155/004437 - Manifold Abs.Pressure Sensor (G71): Circ. Short to B+
Possible Symptoms
    * Limp mode
Possible Causes
    * Connection(s) to/from Manifold Abs.Pressure Sensor faulty
    * Manifold Abs.Pressure Sensor (G71) faulty
    * Pipes/hoses not/wrongly attached
Possible Solutions
    * Check wiring and connections
    * Check / Replace Manifold Abs.Pressure Sensor (G71)
    * Check pipes and hoses
17978/P1570/005488 - Engine Start Blocked by Immobilizer
Possible Symptoms
    * Engine starting but stalling immediately
Possible Causes
    * Key(s) not matched
    * Instrument Cluster not matched
    * Engine Control Unit (ECU) not matched
    * Engine Control Unit (ECU) Power Supply faulty
Possible Solutions
    * Check for Fault Codes in Immobilizer itself (part of Instrument Cluster in many cars, but separate Immobilizer Control Module in some)
    * Check Immobilizer Measuring Values (usually in Instrument Cluster OR Immobilizer Control Module)
    * Match Key(s)/Instrument Cluster/Engine Control Unit (ECU)
    * Check Engine Control Unit (ECU) Power Supply (Relay)
17655/P1247/004679 - Needle Lift Sensor (G80): Open or Short to Plus
Possible Symptoms
    * Malfunction Indicator Light (MIL) ON
    * Pre-Glow Light ON
    * Rough Engine Performance
    * Excessive Emissions
Possible Causes
    * Fuse(s) faulty
    * Wiring and/or Connector(s) from/to Needle Lift Sensor (G80) faulty
    * Needle Lift Sensor (G80) faulty
Possible Solutions
    * Check Fuse(s)
    * Check Wiring and/or Connector(s) from/to Needle Lift Sensor (G80)
    * Check/Replace Needle Lift Sensor (G80)
Offline midz16v
« Reply #2 on: 12 October 2011, 21:18 »
Hi mate,
Thanks for that im giving it a full check over at the weekend,codes have been cleared so see what happens.
Cheers again
martin
Offline daz veedub
« Reply #3 on: 12 October 2011, 21:22 »
no worries  :smiley:
Offline midz16v
« Reply #4 on: 13 October 2011, 18:27 »
Wee update,
Hit limp mode again this morning fired it back on fault scanner and returned the one fault code 17965.
Guessing the turbos clogged up,does anyone know how much hassle it would be to split the turbo and fire in 1 of these...
http://www.ebay.co.uk/itm/Audi-A3-Golf-Skoda-TDI-1-9-GT1749V-Turbocharger-110HP-/350434671978?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item519788bd6a
martin
« Reply #5 on: 13 October 2011, 18:48 »
Wee update,
martin
Better to fit a complete turbo  :smiley:
Offline mcgee9t2
« Reply #7 on: 13 October 2011, 21:24 »
tbh mate, looks like a cheep chineese copy. have a look in the for sale section and on other forums for sale sections, seen a few people lately buying things like this for 240 quid upwards, when ive seen vw turbos go for not much more.
just my opinion though, im no turbo expert.
