Golf mk4
Wazzzer
maf ok but lambda nackered?? wot result
Topic: maf ok but lambda nackered?? wot result (Read 804 times)
rio_gti
"i'm not spending any money on it" Got a Hybrid!
12 October 2011, 13:18 »
as above looks like the pre cat sensor is truly dead??
but the maf appears to be ok as i had 191bhp on the rollers......
2000 GTI 1.8t ARZ, S2000 filter, DSG intake, Forge 007 dv, Catch can, R-tech custom remap, 3" Supersize Silicone TIP, Powerflex dog bone, 'The Beast' FMIC, Ultimate delete, LCR fuel pump, 3" Turbo back, K03 hybrid, Ported Manifold, S3 injectors, 80mm maf = 280bhp 270lbft
littco
Here all the time
Re: maf ok but lambda nackered?? wot result
12 October 2011, 13:29 »
What makes you say the O2 is knackered? The accurate range for narrow band O2 sensors is the .400v to .800v or the 15.0:1 to 14.2:1 AFR ranges. Also there's no correction % which says it's behaving as it should.
Golf mk4
Wazzzer
