Author Topic: 17535 - too rich 17705 - loss of pressure, MOT  (Read 3134 times)
Offline Dan_GTi8v
« on: 12 October 2011, 04:09 »
I'm guessing I'll be fine with the loss of pressure code, but would the running rich code give me trouble at the MOT?
Basically I've been having trouble with my lambda reading and on inspection my lambda sensor was f**ked. Since fitting a new one I'm now getting these codes. The other 2 readings were fine it just failed on lambda reading
I'm guessing that now having a working o2 sensor my emissions wont suddenly fly up and cause a fail, but do you think I'll be fine now with a working lambda to get it retested or will this new code cause me new problems?
Quick answers please its booked in for the retest at 13.45 today! cheers :)
Offline bobbieboy69er
  • MK4 1.8T AUM
Re: 17535 - too rich 17705 - loss of pressure, MOT
« Reply #1 on: 12 October 2011, 09:06 »
think you should be ok, afterall its only exhaust gases that they measure so your 02 sensor is irrelevant really.  Its all down to what is actually spittin out the back of your pipes!  Not what your ECU thinks is coming out
Sounds like it may be the wrong 02 sensor youve fitted or maybe a faulty one....?
MK4 1.8T AUM|30mm Eibach Springs|Milltek cat back|4mo rear valance|pipercross filter|R-tech Stage 1 Remap|Baileys DV|Powerflex Front and Rear Bushes|312mm Front Brakes|Creation Motorsport TIP and hoses|17" TT Ronals|  220BHP
Offline Ant1981
  • Feed me, prod me
« Reply #2 on: 12 October 2011, 09:25 »
Boost leak.
'09 Kawasaki Ninja ZX-6R
Offline brianpologti
« Reply #3 on: 12 October 2011, 10:43 »
As above , boost leak. Mine does this
Offline Dan_GTi8v
« Reply #4 on: 12 October 2011, 11:01 »
Its definitely the right sensor and the garage tested it so its working. Could a boost leak cause the running rich code? all I'm worried about is the lambda reading really as thats all it failed on last time
edit: goddam auto correct :P
« Last Edit: 12 October 2011, 11:32 by Dan_GTi8v »
Offline Ant1981
  • Feed me, prod me
« Reply #5 on: 12 October 2011, 12:35 »
The boost leak causes the running rich, both codes usually hold hands.
Offline Dan_GTi8v
« Reply #6 on: 12 October 2011, 12:41 »
cheers :) I just been reading about it on google found a lot of helpful threads on uk-mkivs so looks like I got my work cut out trying to pinpoint it, screw all that for now though I need this MOT pass today or I'm gonna cry  :cry:
Offline Ant1981
  • Feed me, prod me
« Reply #7 on: 12 October 2011, 12:50 »
I'm sure it'll pass. It'll only go rich for a moment under load with boost.
Offline Dan_GTi8v
« Reply #8 on: 12 October 2011, 12:57 »
yeah I'm not sure if the code is related to the fail as I would of thought if anything too rich would mean not enough o2 in the system? It failed with a high lambda reading but hoping that the new o2 sensor will fix that (old one wires were chewed up from rubbing against the driveshaft!)
retest in a couple of hours so fingers crossed :P gonna take it for a blast in a bit to get it nice and warm, toying with the idea of going to the autofactors and getting some of this emission lowering stuff to mix with the fuel but not sure how much it would help if anything at all
Offline Dan_GTi8v
« Reply #9 on: 12 October 2011, 15:12 »
 Passed  :cool: must of just been down to the lambda wiring  :smiley:
