Author Topic: timing belt  (Read 2426 times)
Offline Dis00
  • MAN i JUST LOVE THE ICE CREAM
timing belt
« on: 26 April 2005, 22:28 »
bought a mk4 1.6 not so long ago its done 55k and my grandad think i should get the timing belt changed he thinks it will cost about 90 is this worth doing and at a good price
cheers
Offline topher
  • Administrator
  • fully functioning
Re: timing belt
« Reply #1 on: 26 April 2005, 22:30 »
60,000 miles or 5 years is the general rule.. but £90 is a bit optimistic.. you're looking at 200 easily .. dont forget to get the belt tensioner changed too !!!
Offline Dis00
Re: timing belt
« Reply #2 on: 26 April 2005, 22:43 »
90 is what the garage said
Offline topher
  • Administrator
  • fully functioning
Re: timing belt
« Reply #3 on: 26 April 2005, 23:03 »
bite their hand off at that price then.. 1.6 might be different but vw quote a mk4 belt change at around £230 .. 3 hours labour
Offline Dis00
Re: timing belt
« Reply #4 on: 27 April 2005, 00:29 »
whats the belt tensioner thing
Offline AudiA8Quattro
Re: timing belt
« Reply #5 on: 27 April 2005, 01:17 »
That will be for the belt only then.
diagnosis-dub
Re: timing belt
« Reply #6 on: 27 April 2005, 02:06 »
It does exactly what it says on the tin.
Its the rather important wheel that tensions the belt. When you do a belt change always replace it otherwise the original one will fail and you have a knackered engine.
Offline nrgizerbunny
Re: timing belt
« Reply #7 on: 27 April 2005, 10:08 »
Do the waterpump at the same time!
cheapest cambelt change i've ever got is for £15 on a toyota starlet, but i did that one myself!  :smiley: has anyone tried a mk4 cambelt change themselves or do they just take it down to the dealers?
Offline kniterider
  • had most, sold most and often buy more!
Re: timing belt
« Reply #8 on: 27 April 2005, 11:59 »
did mine when i rebuild my 20v after the tensioner pully failed....
not too hard, just more of an arse than anything, if i didnt have had to remove the head etc it would have been alot easier, the engine mount you have to remove is a tw@t, also the m5 threaded bar with nuts on (which you need to remove tension from the tensioner spring loaded pin) is a bit of an arse too. but if i had to id do it again as now i know what/how to do it its easier....
although i will say, if you let a garage change it (belt/tensioner) you have the beauty of some kind of fall back if it all goes tits up 10miles down the road...... if you d.i.y it and it goes tits up........
costly....
 :smiley:
