Author Topic: Eibach rear ARB  (Read 1929 times)
Offline Dave_IOW
Eibach rear ARB
« on: 11 October 2011, 22:10 »
Do you have droplinks with them?
I have front and rear and my rear never came with droplinks.
Someone else must have one here and can answer my question..
I have bolted mine to the bolts where your lowest point of the rear strut is, hard to describe, but if you have fitted coilovers or changed suspension its the lowest bolt on the rear suspension strut..
Trying to source the problem of a strong humming noise coming from both rear corners when turning. Got worse when fitted rear polybushes.
Mine....  :huh:
Should it be like the whiteline below?
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline barrym381
Re: Eibach rear ARB
« Reply #1 on: 11 October 2011, 22:28 »
Offline SI74
Re: Eibach rear ARB
« Reply #2 on: 11 October 2011, 22:43 »
Nope yours is fine, You use the longer bolt and push it through the hole in the ARB/Rear sturt and into the rear beam.
Whiteline is made to use them the Eibach is made to be fitted the way you have done.
« Last Edit: 11 October 2011, 22:47 by SI74 »
Offline Dave_IOW
Re: Eibach rear ARB
« Reply #3 on: 11 October 2011, 22:55 »
Cheers bud, search for the mad vibration continues then  :huh:
Re: Eibach rear ARB
« Reply #4 on: 11 October 2011, 23:50 »
Wheel bearings maybe  :undecided:
Offline sveed1.8T
Re: Eibach rear ARB
« Reply #5 on: 12 October 2011, 09:24 »
Didn't patch have an eibach rear arb? :huh: Might be worth sending him a pm?
jamie16v
Re: Eibach rear ARB
« Reply #6 on: 12 October 2011, 11:10 »
+1, does it increase with speed of vehicle?..
Offline Dave_IOW
Re: Eibach rear ARB
« Reply #7 on: 12 October 2011, 17:27 »
Not really, only really does it when cornering, even at like 15mph?
Patchs was a neuspeed arb :smiley:
Offline sveed1.8T
Re: Eibach rear ARB
« Reply #8 on: 13 October 2011, 01:33 »
My bad :undecided: Just remember seeing him with an arb for sale in the classifieds
