Author Topic: knocking in the front somewhere over bumps  (Read 1274 times)
Offline ELCAP1TAN0
« on: 11 October 2011, 21:53 »
right I'm getting a knocking in the front and I've ignored it for as long as I could. I'm not mechanical but want to learn. when my 1.8t had it's mot back in march i had an advisory.....
Offside Front Macpherson strut has slight movement at the upper attachment (2.5.A.1c)
I presume this is the route of my problem? I have no idea what this means but from a bit of googling it seems that a Macpherson strut is the type of suspension. Few questions. How much does this cost in parts to sort out? What do I need to sort it out? is it easy? will this sort out the knocking?
Only reason why I'd rather give it a whirl myself is that due to my one of my engine mounts going and recovery etc, new battery in the process repairs have cost me a fair bit in the last month or so so If I can do it myself I will try just to save on the labour costs.
Offline dam088888
Re: knocking in the front somewhere over bumps
« Reply #1 on: 11 October 2011, 22:16 »
Sounds like your top mounts need replacing mate not that hard of a job really the parts are cheaper ebough. But for a first DIY not sure if I would recommend there are some good how toos about but you will need spring compressers to replace the top mounts hope this helps
2000 agu 1.8t lowered 55mm,cream mirrors and wheels,stage 1 map, forge 007p,
Offline ELCAP1TAN0
« Reply #2 on: 13 October 2011, 20:00 »
Ahh. Righto, well if it is the problem what kind of cost am I looking for a garage to sort out the problem?
Offline GJSEB79
« Reply #3 on: 13 October 2011, 20:14 »
to be honest  a decent garage should change them in under an hour so you would be loking around a hours labour if you supply parts so any where between 25 50 quid mate  :smiley:
