Author Topic: can a AGU engine run at 350bhp with standard internals??  (Read 39950 times)
Offline Chris.
Re: can a AGU engine run at 350bhp with standard internals??
« Reply #60 on: 20 October 2011, 22:45 »
Here we go.  This is with stock OEM injectors, and OEM MAF housing.  Fitted is a Forge Actuator and yellow spring.
If people really dont think actuator makes a difference, id even be prepared to go out and do logs with a forge actuator and stick a OEM actuator on and show the difference in readings.  It really is night and day and probably one of the best mods going if you want to get high figures out of AGU k03s.
What you have said is totally fair and cant get much more spot on that that.....offering to map cars £FOC.   I think people often fall into the ruthole of once a mapper sponsers a forum, they instantly become the best in the land and their results are gospel.
I have graphs here from the very first remap (even no remap on a stock AGU map with k03s) and you can really see the progression of the mods.  The graphs literally speak for themselves.  Shame I dont have a one of the 238bhp we ran on a stock ID" MAF and stock injectors :(
Click For Build Thread
Offline Scott D
« Reply #61 on: 20 October 2011, 23:21 »
those are very very impressive figures from a K03s, graph looks awesome too!
would the larger ID maf housing and c20let injectors work with mapping on an AUM/AUQ?
247bhp is an awesome result and looking that torque curve must be fun to drive
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #62 on: 21 October 2011, 06:59 »
No mate I think you can use S3 injectors, it's just us AGU boys have weedy injectors that hit 100% too soon  :sad:
Offline Hulmie
  • White MK4 1.8T AGU K03s
« Reply #63 on: 21 October 2011, 22:25 »
agu K03s with Calibra yellow injectors, 255 fuel pump = 240+bhp and 290lb/ft torque is the way forward. Speak to R-Tech
Offline lordy-18
« Reply #64 on: 23 October 2011, 18:58 »
i ran 320 bhp without any problems on standard agu internals for 6 months
Offline lordy-18
« Reply #65 on: 23 October 2011, 20:16 »
no went forged internals now running 400bhp + plans to see 500 next year when i first started building mine i spoke to few different companys 1 being jabbasport who said they have tuned 1.8t engines for 10 years and ran 100s of cars at 300+ bhp on standard agu internals without any problems as long as its tuned properly (rtech)
Offline Chris.
« Reply #66 on: 14 February 2012, 01:41 »
I love reading through old topics!
high 250s and ~300lbft will be coming in 2012 for my engine.....watch this space!
Offline yamz89
« Reply #67 on: 14 February 2012, 13:20 »
my friend i want more power than 150bhp
a remap will give you more than near 200hp. Have you tried that?
yeah have tried that with my last engine was running 240bhp but now i want to sit in the 300 - 400bhp mark or in the middle ;)
Very much doubt it was 240hp unless it was a remapped BAM / amk. 240hp is optimistic on a remapped k03s.
Read em and weep :D - That's at low boost too. If you think that's hurting the turbo message Nick @ R-Tech and he will tell you different.
71' Beetle in Marina Blue
05' Octavia vRS
10' Golf GTi
Offline Chris#101
« Reply #68 on: 14 February 2012, 19:20 »
I was told a ball point figure to expect around.240bhp From my auq 180 with
 forge tip
3" turbo back non res exhaust
Forge actuator with yellow spring
Cai induction kit
FMIC
Uprated Recirc valve
Is that a bit ambitious??
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline yamz89
« Reply #69 on: 14 February 2012, 21:06 »
Nope, about right, all depends on the condition of your engine, actuator and if you have any boost leaks.
I run a AUQ in my Octavia vRS with the following mods -3" Inch Decat into 2.5" Piper system, G60/VR6 Clutch Conversion, Poly'D Dog Mount, Forge TIP, Pipercross Panel Filter, Pro Alloy Intercooler, R-Tech Stage 2 Custom Map (245bhp/250ftlb), Oil Catch Can, PCV, SAI and N249 delete
05' Octavia vRS
10' Golf GTi
