Author Topic: can a AGU engine run at 350bhp with standard internals??  (Read 33330 times)
Offline golf-sib
  • Турботазик
Re: can a AGU engine run at 350bhp with standard internals??
« Reply #40 on: 14 October 2011, 21:42 »
Any dyno is a lottery, your figures will vary from time of day to time of year, that is a k03s on an AGU... he's got:
63.5mm exhaust
1.8 NA camshaft
large injectors
Forge cold air intake
Forge actuator (blue spring)
Stock K03s turbo
4bar FPR
Larger MAF
FMIC
Tested on Maha dyno, 100octane fuel, 25degree advance... and it's in a polo.
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline tshirt2k
  • Been there...Done that...
« Reply #41 on: 14 October 2011, 21:57 »
If that's the case, there wasn't much point putting up that dyno plot, as it's outside the scope for the the everyday owner. Anything that can delay the onset of det, will give higher outputs. You could also add a 50hp shot of nitrous and get the same result.
Mk3 ABF 16VT Megasquirt V3
Offline Dave_IOW
« Reply #42 on: 14 October 2011, 21:59 »
Its still on a KO3s and proven, you could add water injection and get some advance.
Its possible..
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #43 on: 14 October 2011, 23:41 »
We'll see what Chris gets out of a K03s on Wednesday
Offline +49
« Reply #44 on: 18 October 2011, 14:53 »
What i'm more interested in wen its comes to AGU/k03s combos is why ppls torque figures differ so much so very similar setups?
theres loads of 220-230 BHPS once but have 250-60ft lb of torque? Then some with 238bhp only have 235-240 fl lbs? is the the dyno? different tuners? Just luck?
Rtech seems to get very high torqure figures? Is is it just cos he's the bollox?  :grin: :wink:
Offline piperrs
  • Piperexhausts.co.uk
« Reply #45 on: 18 October 2011, 15:01 »
My K03S AUM made 230BHP 265 ft/lb at AMD.
Tel - 01303 245 300
Fax - 01303 240 666
Email - sales@pipercams.co.uk
Offline +49
« Reply #46 on: 18 October 2011, 15:05 »
for instance these fitures? 265ft lbs?!?!
Offline Sammie-GTI
« Reply #47 on: 18 October 2011, 20:56 »
wasn't there someone in golf+ who ran 247bhp 285lbft with agu ko3s? :shocked:
Offline Chris.
« Reply #48 on: 19 October 2011, 00:32 »
Sooooo many things to think about really.
Ill see what mine gets in the morning with the following:
k03s
AGU (recently rebuilt
3" decat downpipe
2.5" cat back to remus backbox with no center silencer
forge actuator (yellow)
forge 007p (yellow)
forge TIP
New N75 I think its a 'E'
2.75" ID MAF
Pipercross panel filter in stock oem smoothed airbox with 3" cold air feed
THS FMIC
calibra yellow injectors
No cams or anything else internally (its a stock AGU block with k03s) with just about every bolt on going :|
Looking at getting into the 240s
ran a 238 whilst lean last time on the dyno with stock maf and injectors.
Click For Build Thread
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #49 on: 19 October 2011, 12:48 »
How you done so far Chris? Only thing I'll have different to you is a 2.5" decat rather than a 3"
