Author Topic: Bare minimum to get a AGU 1.8T to run  (Read 7554 times)
Offline Chris.
« on: 10 October 2011, 19:33 »
Hi
Does anyone know what the BARE minimum you need to get a AGU engine running?  ECU will be de-immobilised.
Plan to put a AGU engine into a clio MK2 172 and getting everything in is straight forward, just need to know what wires effectively are needed to get it to run and have working speedo/rev counter.
Ive thought of:
speedo
ignition sense
rev counter
coolant temp
I ahve a feeling these wires go through the 3 plugs under the wiper motor so shouldnt be too much hassle to get to to put into a clio loom.
Just need some more information really.
Chris
Click For Build Thread
Offline tech1889
  • Mk2 GTI FTW !!
Re: Bare minimum to get a AGU 1.8T to run
« Reply #1 on: 10 October 2011, 19:38 »
why you need bare minimum ??
your going to need quite a few wires as its not an old engine so is a lot more complex and the 1.8t doesnt like running without certain sensors plugged in such as MAF.. Temp sensor.. Depending what engine you may need a MAP sensor wired in..
Let us know why bare minimum and we can work out the rest  :wink:
Offline Chris.
« Reply #2 on: 10 October 2011, 19:39 »
Well maf sensor and all other sensors will be put on.
Just I basically need to know, what does the AGU ECU need to 'see' before it will run.  So effectively, splicing a clio loom into a 1.8T loom to get them working together.
Hope that makes sense.
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #3 on: 10 October 2011, 19:41 »
well your going to need the whole AGU engine loom atleast.. and then you can splice the clio headlight loom into that.. christ knows fuse box end.. but theres not a lot you cant plug in tbh..
Offline Chris.
« Reply #4 on: 10 October 2011, 19:42 »
Got a AGU engine loom.
I have a feeling most the wires that are actually needed go throuhg the 3 plugs under the wiper motors.
Offline RTechUK
  • R-TECH OFFICE 01455 617233
« Reply #5 on: 10 October 2011, 22:02 »
Hi
Ive thought of:
speedo
ignition sense
rev counter
coolant temp
Chris
Qpeng :wink:
 01455 617233
Offline Chris.
« Reply #6 on: 10 October 2011, 22:03 »
In a clio?  Didnt know they did it?
Dont even think anyone has a 1.8T in a clio mk2 with OEM management?
Offline RTechUK
« Reply #7 on: 10 October 2011, 22:24 »
They dont do a setup fo rthe clio, they  do it fo the AGU engine with golf mk1/2/3 setups but at the end of the day its only an MBE ecu so you can get it to work with the Clio rev counter and ignition ect, just will a little extra effort and a few chopped wires.  Plus I have the CANbus MBE mapping leads and sw with around 10 mapswhich I have made over the last 18month. :wink:
 01455 617233
Offline Chris.
« Reply #8 on: 10 October 2011, 22:25 »
no idea what this MBE stuff is ha.
You dont know what wires you need to get it in and running do you?
« Reply #9 on: 10 October 2011, 23:54 »
Your going to need the engine loom I think.
Have seen a few done however so it can be done.
 :smiley:
