Author Topic: short shift  (Read 3300 times)
Offline mkviken
short shift
« on: 09 October 2011, 19:15 »
anyone fitted a short shift kit yet?
i have looked at the forge and the dieselgeek and VWR ones
any others to consider? how much is the VWR?
anyoneused or can recommend one based on quality and ease of fit/adjustment?
thanks
Golf GTI 7.5 230 white silver
Jimmymature
Re: short shift
« Reply #1 on: 09 October 2011, 19:58 »
thanks
The VWR version is £125 + VAT.
Jim
Offline mkviken
Re: short shift
« Reply #2 on: 09 October 2011, 20:08 »
do you know it it is adjustable?
Jimmymature
Re: short shift
« Reply #3 on: 09 October 2011, 20:21 »
Sorry mate, no idea I just have their price list for all their products.
Jim
Offline SteveP
Re: short shift
« Reply #4 on: 09 October 2011, 20:49 »
two way adjustable, i.e throw and side to side  :smiley:
Offline mkviken
Re: short shift
« Reply #5 on: 09 October 2011, 21:02 »
just found a neuspeed one which looks pretty good. its not shorter side to side, just front/back.
it doesn't require any cable adjustment after fitting so is easier to fit than the forge one and the diesel geeks one looks a right faff on. might be worth a go
Offline simonjj
Mk7 GTD, 3 door, night blue, 19" Neuspeed RSE10
Offline hatchfanatic06
  • I'll get it right eventually.....
Re: short shift
« Reply #7 on: 10 October 2011, 13:07 »
Another contender:
http://www.twmperformance.com/shortshifters/volkswagenshortshifters/volkswagenmk6gtishortshifters.htm
I've heard amazing things about the twm one and will be purchasing this one in the near future. Its not side to side but me personally i do not like side to side. It is counterweight adjustable for that OEM feeling. (i.e. can either be really mechanical and notchy or smooth.)
APR Stg 2 // APR TBE // APR Stg 1 Carbonio CAI // KONI Coil-Overs
My Build Thread
Offline mkviken
Re: short shift
« Reply #8 on: 10 October 2011, 18:35 »
i find the side to side action not to bad but the front to back throw is a bit much
i like the look of the neuspeed one as its a straight swap with no adjusting cables required.
Offline mkviken
Re: short shift
« Reply #9 on: 13 October 2011, 14:51 »
i bought an audi S3/TTS OEM short shift for my car from the main dealer
should get it saturday morning. apparently its the last one in the UK and they're now on back order till mid November.
its for the mq350 gearbox so should fit mk5 onwards 6 speed golfs, and all VAG with newer 6 speed box's
audi part number is 8J0711046E. it was £27
it looks identical to the GTI one apart from the pin the cable end fits on is about 10mm closer to the centre pivot spline.
it doesn't work side to side, just front to back. for the money it seems ideal and though has a shorter throw retains the OEM feel.
« Last Edit: 13 October 2011, 14:54 by mkviken »
