Author Topic: dials reading wrong  (Read 2393 times)
Offline Dizzie
  • Make friends with your fast
dials reading wrong
« on: 19 September 2003, 00:13 »
when I put the white dials on I foolishly removed the needles and now I can't get them reading right. is the best way to sort this out to get another set of dials and set the car idling at say 3000rpm then swap the dials over and push the needle back on in the right place or is there an easier way to do this?
ty
Offline TIM
Re:dials reading wrong
« Reply #1 on: 20 September 2003, 01:51 »
My golf gti 91 8 valve does 3,500rpm in fifth doing about 80mph.
Offline Dizzie
« Reply #2 on: 20 September 2003, 15:59 »
my '87 8v reads almost 4500rpm when doing 80mph in 5th  ???
Offline benjam_in
« Reply #3 on: 20 September 2003, 20:28 »
mine reads about 7000 but then the clutch is ruined!  :'(
Golf Mk2 Gti 1988
Offline modulater
« Reply #4 on: 21 September 2003, 12:00 »
You have to remove the needles on most dial kits otherwise its a right pain in the arse. both dials have a stop poking out that the neddle rests against at rest, you should be able to get the needle just resting against it.
I'm sure this must be covered on a few of the websites out there.
Offline Dizzie
« Reply #5 on: 21 September 2003, 15:44 »
trouble is where the speed needle rests on the pin is 10mph. so the speedo reads 10mph fast so it's difficult getting it in the right place.
with the revs I set it to 0rpm, but then on tick over/idle it was reading like 500rpm. a bit low i thought.
anyways. will be putting 16v clocks in soon ready for the 20v T :D
