Author Topic: Difference between AGU and AUM blocks  (Read 8056 times)
Offline Chris.
Re: Difference between AGU and AUM blocks
« Reply #10 on: 09 October 2011, 18:24 »
AGU has the large port head, but I guess VVT from the later ones could be put onto a AGU?
AUM does have its advantages in terms of mapping software(ecu firmware) as more can be mapped in but then i have to change pedal box etc etc and everything that goes with it.
Im not sure which ECU id run if i went big turbo tbh. AGU is certainly the easiest to put in, but does it map aswell?
Click For Build Thread
jamie16v
« Reply #11 on: 09 October 2011, 19:18 »
i would look into building the head too, apparently the valvetrain isnt all that good for big power so i would look into uprated springs at least.
Offline golf-sib
  • Турботазик
« Reply #12 on: 09 October 2011, 19:30 »
Surely the VVT will be more beneficial? No one has yet got a VVT on the AGU, but anything is possible I suppose.
What about a diesel bottom end I heard they fit direct, but please check this.
What about enlarging the valves, this could be a possibility, or just look into improving the profile of the valves and seats.
Advantage with the AUM ecu is getting traction working due to the DBW system in place, handy in lower gears with plenty off power.
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline shaft69
« Reply #13 on: 09 October 2011, 20:36 »
I know from years ago AGU and BAM have forged internals and take bigger power than rest of 20vt engines.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline james2
  • No scammers please.
« Reply #14 on: 09 October 2011, 21:36 »
i would stick with agu, poor r-techs golf .But i blame it on nos.How about bore it out ,wouldnt worry about bigger valve its got 5 in each pot  :laugh: some good kent cams . :drool: Try and get all parts for stage 3 map. Just leave nos out. :laugh: unless you ceramic coat the valves and piston tops. :tongue:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline Chris.
« Reply #15 on: 09 October 2011, 21:36 »
wouldnt want to go over 380bhp on the valves like....heat really does kill them!
Offline james2
« Reply #16 on: 09 October 2011, 21:38 »
nos wouldnt help.But you should be fine with out it. :wink:
Offline golf-sib
  • Турботазик
« Reply #17 on: 09 October 2011, 21:44 »
The 2Litre stroker kits seem to be a fav amongst the audi boys, 2.0T 20V  :smug: now we're talkin'
1.8T AGU..
R135
  24
Offline james2
« Reply #18 on: 09 October 2011, 22:46 »
Now your talking, in a golf would kick arse with a big turbo :drool:
Offline Dan_GTi8v
« Reply #19 on: 10 October 2011, 10:32 »
If I can fit it into a mk3 a mk4 should be a walk in the park :)
