Author Topic: handling?  (Read 1947 times)
VeeDubGTI16v
handling?
« on: 09 October 2011, 11:47 »
ok, who has found a good setup for the mk4 that doesn't affect the ride too much? I guess massive arb's would be the best starting point and all the rubber upgrade bushes eg vrs, tt etc. what dampers work well on the mk4?
Is it possible?  :laugh:
Offline richw911
Re: handling?
« Reply #1 on: 09 October 2011, 12:11 »
No stick to the mk2  :grin:
VeeDubGTI16v
Re: handling?
« Reply #2 on: 09 October 2011, 16:41 »
 :grin:
i'm not after miracles, just an improvement
anyone got a arb set on std dampers?
Offline richw911
Re: handling?
« Reply #3 on: 09 October 2011, 16:44 »
:grin:
Rhyso did with his for a while iirc  :smiley:
jamie16v
Re: handling?
« Reply #4 on: 09 October 2011, 19:23 »
go for a whiteline rear anti-roll bar for a massive improvement. then go for a "decent" shock/spring combo. avoid fk and jom and spent a bit on something that will last.
Re: handling?
« Reply #5 on: 09 October 2011, 21:34 »
Bilstein shocks and eibach springs is a great set up.
VeeDubGTI16v
Re: handling?
« Reply #6 on: 13 October 2011, 07:14 »
Just the rear arb jamie? I suppose i could fit that first and if the back is too lively then fit a front as well
Offline Rhyso
Re: handling?
« Reply #7 on: 13 October 2011, 09:04 »
:grin:
I did indeed.  Started with a Whiteline Rear ARB.  Ran that for a while on standard shocks and springs.  Then I lowered it with Eibach's.
I then upgraded to Audi TT wishbone bushes.  Final mod was Bilstien B4 shocks and new topmounts.  All in, it was a decent improvement although the ride was quite firm  :undecided:  Probably me not being used to new shocks more than anything  :grin:
jamie16v
Re: handling?
« Reply #8 on: 13 October 2011, 11:22 »
yes, i just fitted the rear to compensate the overkill front arb which gave the understeer. the rear one will reduce the understeer massively. you could go for a front and back kit providing they are from the same company and kit, then they should compliment each other. my shock/spring combo was a jamex sportline kit which was great for the first year, was really stiff and was going nowhere, but it was cheap and didnt last the warranty. i was desperate for something fast so got something cheap again.
these were fk-ak street coilovers, ok for that lowered look but dont handle as i expected them to. if i get rich one day i will invest in something fully adjustable and with a bit of quality.
