Author Topic: Vacuum in fuel tank...  (Read 1657 times)
Offline tiggerhayes
« on: 08 October 2011, 20:56 »
When I remove the fuel cap there's always a vacuum, but recently it's got alot worse and fuel sprays out as the cap is removed  :shocked:
Today, it spluttered as I was driving as if it was running out of fuel, but there was plenty.  I got out and had a look and there was fuel leaking out the back.  I removed the cap very carefully and I could hear things relaxing as the pressure was released.....  :sad:
There must be a breather blocked somewhere, but I don't know where to start....  :huh:  There's a small nozzle just inside the fuel pipe which can be wiggled??  :rolleyes:
Offline barrym381
Re: Vacuum in fuel tank...
« Reply #1 on: 08 October 2011, 21:11 »
http://www.golfgtiforum.co.uk/index.php?topic=188935.0
have a read here bud this guy had the same prob
« Reply #2 on: 08 October 2011, 21:29 »
I suspect your breather hose is blocked or kinked.
Offline tiggerhayes
« Reply #3 on: 08 October 2011, 21:50 »
Thanks!  Is the little nozzle just inside the fuel pipe the breather?   :undecided:
