Author Topic: Uprated side intercooler  (Read 4361 times)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Uprated side intercooler
« Reply #10 on: 08 October 2011, 20:40 »
Cool, I couldn't tell you where it is :grin:
Offline shaft69
« Reply #11 on: 08 October 2011, 21:09 »
What vents do you use n wheel arch???
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline houston
« Reply #12 on: 08 October 2011, 21:15 »
you can use the ones off a tt, or make your own.
wazzer, when i look the funnel was blocking a fair bit of the ic, did nick test to see the benefits of keeping it? either way i suppose its too late as mines in a tip somewhere now
Offline james2
  • No scammers please.
« Reply #13 on: 08 October 2011, 22:04 »
The vent in the wheel arch, i got from b&q £4.99 . :tongue: ill cut a square hole and black silcon it with 4 pop rivets holding it on. I got the idea from looking at a newer car when i was painting car park markings at work. :grin:
« Last Edit: 09 October 2011, 15:53 by james2 »
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline shaft69
« Reply #14 on: 08 October 2011, 22:21 »
sounds good to me mate, get wife to get one she's manager of b&q in liverpool. sorted.
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline james2
« Reply #15 on: 08 October 2011, 22:25 »
lol, its a cheap alloy one the vents face down 9x4 i think but im chopping it down and spray it black. :drool:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #16 on: 08 October 2011, 22:31 »
It's to do with channelling the air to the cooler and then allowing it to escape. There is a bit of theory behind it ie low and high pressure points creating voids bit it's a lot to try and explain.
The main reason for it is the air hitting the front of the cooler is not very efficient without the means to escape. Also with the funnel you are forcing the air to hit the IC and not just glance off
Offline daz veedub
  • Operation 1.8t bolf
« Reply #17 on: 09 October 2011, 13:57 »
any1 have any pics of the arch venting on there golf
Offline james2
« Reply #18 on: 09 October 2011, 15:56 »
I found 1 by searching it on here.It was a tt one he bought and put it in his arch.Have a search on here took me a bit to find. :laugh:
Offline golf-sib
  • Турботазик
« Reply #19 on: 09 October 2011, 19:40 »
I remember autospeed adding a vent to the wheel arch, it did F all. Reason being was the vent design was not efficient enough in improving air flow and it had no effect on the pressure under the arch which is what they where testing and measuring in the experiment, instead they decided to use a FMIC do to a bigger access of inlet air flow on a pd engine which are far more on boost than our engines, have a read:
http://www.autospeed.com/A_108646/cms/article.html
http://www.autospeed.com/cms/A_112259/article.html
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
