Author Topic: forge 007 dump valve  (Read 2263 times)
Offline gti_boz
« on: 07 October 2011, 19:29 »
fitted a forge 007 dump valve to my 1.8t agu golf.. i was told they dont make that much noise but mine makes pretty much non what s ever.. the standard one makes alot more noise.. just wanted to check this is correct?
cheers :)
Offline paul54
Re: forge 007 dump valve
« Reply #1 on: 07 October 2011, 19:34 »
Check for boost leaks first. A common area in on the TIP
04' Golf GTi 180-6
10' Golf GTi
Offline daz veedub
  • Operation 1.8t bolf
« Reply #2 on: 07 October 2011, 19:45 »
standerd airbox or induction on ?
Offline gti_boz
« Reply #3 on: 07 October 2011, 19:54 »
standard box and filter but box has been drilled
Offline daz veedub
« Reply #4 on: 07 October 2011, 19:55 »
wont make much with airbox mate if u want noise whack an induction kit  :smiley:
« Reply #5 on: 07 October 2011, 21:10 »
Mine on a standard airbox is not that loud.
Offline golf-sib
  • Турботазик
« Reply #6 on: 07 October 2011, 21:41 »
Mine dumps in first and second and then the higher gears make pew pew noises  :laugh:
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline s-l-i-x
  • Golf MK4 1.8T AGU
« Reply #7 on: 07 October 2011, 22:00 »
The standard DV probably made noise because it was knackered and the diaphragm was split so making a chatter noise...
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #8 on: 07 October 2011, 22:43 »
:afro:
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
« Reply #9 on: 07 October 2011, 22:53 »
I have one on my Leon AUQ 1.8t along with a cone filter and it sounds great although I think I may be running a wee bit more boost than the AGU. Removing the bonnet lining will also allow more noise to be heard. Other mods like an upgraded TIP will also help you a bit.
