Author Topic: oil light / compression ?  (Read 1393 times)
Offline darer
« on: 07 October 2011, 17:33 »
hi everyone just bought a golf mk4 gti 1.8, 125, 5 door. :smiley:
problem i have is when driving about for about 1 hour the oil red light comes up and beeps every now and then,
i have just bought a compression tester, does anyone know what the correct compression should be for my model
or any other advice on what could be the problem, the seller told me he had changed the sump couple weeks back.
thanks.
reece
Offline Dave_IOW
Re: oil light / compression ?
« Reply #1 on: 07 October 2011, 18:58 »
pick up pipe, oil pump, oil level?
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline richw911
« Reply #2 on: 07 October 2011, 18:59 »
What service history do you have with the car?
Is there oil in it?!!
What oil grade does it have in it?
Sounds like its not been looked after and the sump oil strainer is blocked.
Dont drive it until you have sorted it  :wink:
Offline golf-sib
  • Турботазик
« Reply #3 on: 07 October 2011, 19:04 »
Changing sump usually mean just changing the pickup pipe as this can get blocked.
I'd start with the pickup and fresh oil, if this fails it could be the oil pump.
Compression should be a minimum of 7Bar (103psi) according the Haynes with no more of a maximum difference off 3Bar (44psi) between cylinders
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline Dave_IOW
« Reply #4 on: 07 October 2011, 19:13 »
Thats alot of difference betwwen cylinders  :shocked:
Maybe they put too much sealant on sump and its blocked the pick up?
Offline paul54
« Reply #5 on: 07 October 2011, 19:35 »
Check oil level.
04' Golf GTi 180-6
10' Golf GTi
