Author Topic: Changing my suspension on mk2 16v which ring spanners do i need?  (Read 1850 times)
Offline H Singh
Hi guys
As the subject states, which ring spanners will i need to change the suspension. i know i need a 22mm for the front i believe? how about the back??
Harry
« Last Edit: 07 October 2011, 15:15 by H Singh »
Offline pigbladder
pretty sure its 17mm on the rear
Offline DOA
Im assuming you mean to use them so that you can hold the top of the strut with an allen key through the ring spanner. Most of the rear struts I have seen have a flat or somesuch that you can hold without geting in the way of undoing the nuts with a normal spanner. You can buy sockets that can be held by a spanner that I tend to use for the front struts. If you havent done the job before, make sure you have something to undo and re-do the silly castelated nut.
Offline X4MGS
  • VAG Parts SNOB!!!
One that fits... You don't need a ring spanner for the rear as there is no stupid slotted nut!!
Simple metric ratchet set will do all that you need too do!
For More Info Click To See;
Offline H Singh
Yeah I'm having trouble
With the slotted nut on the front! Pain in the ass it is' trine find a socket set that allows you to gold the nut and allow the Allen key in swell as turn it using a adjustable connected to it to turn it! Fun times hey!
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
http://www.golfgtiforum.co.uk/index.php?topic=164364.0
have a look on the second page on this thread
Offline DOA
If you mean the castellated nut under the main nut then a screwdriver and hammer will do the trick at a push but I tend to attack a roughly similar sized socket or bit of tube with a grinder to get it off (I then lose that and have to do it again next time lol). It helps to either do this bit whilst the car is on the floor or to jack the front upright up to releave the tension on the nut.
Offline H Singh
cheers for all the help guys, swan neck ring spanner is the way forward! lol
