Author Topic: Gti_Jamo's White Mk3 Golf Gti....HOME WITH NEW PICS!  (Read 207214 times)
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
What it is the purpose of the factory metal heat shields?
Keep exhaust temps up? protect the floor pan?
 :huh:
Well the tunnel heatshield's main priority seemed to be attempting to rot out the tunnel but yeah basically its to protect it from heat getting into the cabin.
Offline stow1985
  • 'when im cleaning winders'
 :huh:
So in that case I can scrap the F*ckers then   :evil:
Offline Gti_Jamo
Yeah.....i'm only doing away with the tunnel one and the shield that wraps the downpipes. Unsure about the bulkhead shield as its a bit scabby and wont look nice in my new engine bay.
Offline BISSONE
You thought about the diesel one with the sound deadening matt on it aswel? Mite not look too bad black against the white bay? Just a thought  :smiley:
Offline Gti_Jamo
Going to the dealers today to pick up a few bits so will see if a new one is cheap enough.
Offline SoundillusioN
 :shocked:
Not cutting any corners on this then!...
Will be a very solid car when done.
Not really a fan of MK3's but you obviously are and you seem to be very thorough so far.  Hats off to you.
Offline Gti_Jamo
:shocked:
Cheers mate....To be honest wasn't a huge fan, more of a Mk1 or Mk2 fan but was looking for a project and this came up first. They have grown on me though during this build because the way I see it if your an gti fan and want the old skool look with some modern touches then the Mk3 is the best all rounder. But prob look to do a Mk2 or maybe a raddo next. The Mk3's more of a test run  :grin:!!
:shocked:
Fair play.. good testing so far then. Get a fleet going, Finish this then apply the same work to a MK2, then a mk1!  :grin:
Offline Gti_Jamo
:shocked:
Well thats the plan. Probably need to sell the Mk3 to fund next project though as ive spent way over than I would have liked to.
Offline Seanl
As Shaun says, very thorough job and hats off to you for the job you've done. Problem is with spending so much on this project, you won't make it back. You will more than make up for it in experience and confidence though, so don't be disheartened by that. Raddo next, you know it makes sense!  :grin: :wink:
