Author Topic: pc upgrade question  (Read 2340 times)
Offline shepgti
pc upgrade question
« on: 06 October 2011, 18:34 »
right with the new battlefield around the corner i want to play it on the computer(as we all know thats where fps belong!)
now i dont feel my current pc spec will be up to the job. its a quad core hp (cant post spec till im at home on the comp)
what are the main things i would be looking at upgrading?  graphics card, more RAM?
i know a little about computers but not a huge amount.
Offline justalex81
Re: pc upgrade question
« Reply #1 on: 06 October 2011, 19:05 »
main thing is graphics card.
at least 4gb of ram
rapid hard drive
Offline shepgti
« Reply #2 on: 06 October 2011, 19:12 »
will their be an issues with compatibility if say i bought a gtx460 and some extra ram(is it just a case of slotting it in?)
Offline Ridg
  • TDI - Soot Happens!
« Reply #3 on: 06 October 2011, 19:27 »
depends on your motherboard i.e. does it have an PCIe slot?  Basically if you've got the right slot then it should just slot in.
BF3 is going to be quite CPU intensive so you might want to look at that too
NB a GTX460 requires power, so you'll need to check you PSU for a PCIe power connector or at least 2 spare molex (the standard 4 pin).
« Last Edit: 06 October 2011, 19:31 by Ridg »
Offline Ant1981
  • Feed me, prod me
« Reply #4 on: 06 October 2011, 19:31 »
pci-e you'll be wanting. My guess is yes it'll have one, they've been around for long enough.
Can you afford more for a graphics card? The 560ti's are probably about £200 or so now.
'09 Kawasaki Ninja ZX-6R
Offline shepgti
« Reply #5 on: 06 October 2011, 19:42 »
Not looking to spend too much, just enough to run battlefield without lagging. ill post up some more details about my pc tomoz so you guys can give me some guidance.
Offline Ridg
« Reply #6 on: 06 October 2011, 20:14 »
+1
the 560ti is about £160 these days, faster and less power.
the 460GTX will quite happily run BF3 though.
Offline shepgti
« Reply #7 on: 07 October 2011, 10:35 »
ok so my current spec is
2.2ghz quad core
3gb ram
geforce 8400 1512mb
so i guess i would need a new graphics card and a little more ram
Offline justalex81
« Reply #8 on: 07 October 2011, 10:42 »
yes to the graphics card.
find out how many memory slots you have. you want at least 4gb in dual channel.
the processor is a little on the slow side too and will struggle a bit but should be ok
don't go mad on the graphics card as your motherboard/cpu/memory will be causing a bottleneck so no matter how fast your graphics card is, it will be held back. i wouldn't spend more than £125 on a graphics card if i were you.
Offline Khare
  • The bear that khares
« Reply #9 on: 07 October 2011, 11:49 »
http://www.pc-titan.com/product_info.php?currency=GBP&info=p7473_PowerColor-Radeon-HD-5770-ATI-Design-V2--1GB-GDDR5--2x-DVI--HDMI.html
That's the graphics card I've got, and it'll happily play all the latest games (including bf3) on the highest settings without any lag. I do however have a decent mobo/ram/cpu/psu package though so there's not a bottleneck anywhere in the system, especially as I've overclocked the cpu from 2.9 ghz to 3.5ghz and the gpu (graphics card) from 850 mhz clock and 1200 mhz memory to 920 mhz clock and 1300 mhz memory. It'll happily play games all day long without lag  :smiley:
