Author Topic: ------- ignore found problem------- Airbag fault code fou  (Read 2055 times)
Offline mattyg127
any help would be good, basically when i bought my golf the airbag warning light came on, put it to vw and they said it was the slip ring. so they cleared the code and off i went.
last month it came back on so i plugged it into vcds and got this code
VCDS-Lite Version: Release 1.1
Friday, 09 September 2011, 20:06:55.
Control Module Part Number: 1C0 909 605 A
  Component and/or Version: 27 AIRBAG VW51 01   0004
           Software Coding: 12855
            Work Shop Code: WSC 31414
                      VCID: 2237698BBDC1
1 Fault Found:
00654 -  Seat Belt Tensioner Igniter; Driver Side (N153)
        33-10 -  Resistance too Low - Intermittent
Any ideas on what it could be? couldn't find any info online
cheers in advance
« Last Edit: 06 October 2011, 23:23 by mattyg127 »
Mk4 1.9tdi SE PD100 :D...
Offline mattyg127
Re: Airbag fault code
« Reply #1 on: 06 October 2011, 14:52 »
its ok i was being a spoon when searching found some info on it... cheers can a mod delete this thread?
