Author Topic: do i really have to changed my pedal box for the agu pedal  (Read 2185 times)
Offline mk4_gti
changing my aum pedal to agu is impossiable is there a way to use the dbw system ?
Offline topher
  • Administrator
  • fully functioning
Re: do i really have to changed my pedal box for the agu pedal
« Reply #1 on: 06 October 2011, 16:17 »
need a dbw ecu and loom if you want to use the dbw pedal. Shouldn't be that hard to knock up a simple cable throttle pedal though?
Offline mk4_gti
« Reply #2 on: 06 October 2011, 18:56 »
it is mate when u have nowere to mount the pedal
Offline Chris.
« Reply #3 on: 06 October 2011, 19:26 »
Can imagine there is somewhere to mount the pedal.
Why you changing it to cable?
Click For Build Thread
Offline mk4_gti
« Reply #4 on: 06 October 2011, 19:29 »
erm i had a AUM engine and it blew so i wanted to get the agu engine for the bigger ports but this conversion in a mk4 is weird
Offline Chris.
« Reply #5 on: 06 October 2011, 19:31 »
Put the AUM throttle body on the AGU inlet ;)
Offline mk4_gti
« Reply #6 on: 06 October 2011, 19:45 »
but will that work...dont the ecu have to tell the throttle body when to open
Offline Chris.
« Reply #7 on: 06 October 2011, 19:47 »
Well it depends what you are going to do?  Are you going to use the AUM ECU?  if so, you will need to keep the DBW throttle pedal.
If your going for a ful AGU conversion (ECU aswell) then you will need the cable pedal box.
Why not put a AGU head and inlet  with the AUM VVT and throttle body onto a AUM block?  Even a AGU block might work depending what sensor differences there is.
Offline mk4_gti
« Reply #8 on: 06 October 2011, 20:44 »
nooo im using agu set up  :sad: is there a quide on how to do this
