Author Topic: Foil strips on sills/kick plates  (Read 1627 times)
Offline dscam
« on: 26 April 2005, 01:27 »
Hi folks,
Similar to my other post....I am also seeking a set of black textured 'foil' stick on strips that fit on the inner sill/kick plate on a 3dr Gti (protects the paint from the plastic sill mouldings)...anyone know where I can get these?
All help and advice appreciated!
Duncan
Offline dscam
Re: Foil strips on sills/kick plates
« Reply #1 on: 27 April 2005, 12:44 »
Since posting I've been searching for these parts and as I suspected they've been deleted from VW's parts supply :(
Best solution I have found which might be useful for anyone else requiring these type of parts is that Partco (various brnaches in UK I think) supply an almost identical sill trim tape on a roll which you can then cut to fit and shape.  Not too expensive either at around £10 mark.
It is finished in an almost identical finish to the genuine VW stuff with the textured feel on it....would work on rear tailgate too!
Hope this helps,
Duncan
p.s.
Just found out my paint code LA5U is Royal Blue Metallic and not Helios Blue as I'd always thought!!!
Is this a rare colour?
