Author Topic: bigger maf  (Read 1564 times)
Offline dam088888
bigger maf
« on: 05 October 2011, 20:58 »
Hi all got a agu 1.8t with stage one if I put a 3" maf on will I see more power or not
2000 agu 1.8t lowered 55mm,cream mirrors and wheels,stage 1 map, forge 007p,
Offline richw911
Re: bigger maf
« Reply #1 on: 05 October 2011, 21:08 »
Not
Offline rio_gti
Re: bigger maf
« Reply #2 on: 05 October 2011, 21:10 »
Can u just put one on or does it need to be mapped in??
Offline daz veedub
  • Operation 1.8t bolf
Re: bigger maf
« Reply #3 on: 05 October 2011, 21:12 »
will benefit with bigger maf with next stages
Re: bigger maf
« Reply #4 on: 06 October 2011, 00:01 »
No point fitting it until your running big power.
Offline rio_gti
Re: bigger maf
« Reply #5 on: 06 October 2011, 09:08 »
i only asking cos my one is shot but i got one from a V5 sitting around and wondered if it would work the same if i bolted it on....  :huh:
Offline Dave_IOW
Re: bigger maf
« Reply #6 on: 06 October 2011, 10:12 »
No as the sensor works off volume travelling through it I believe, so wouldnt be right.
Blow through a straw, then blow through a drainpipe, the sensor in the drainpipe would need a lot more air to get the same reading.
So your v5 would be under reading and then ecu under fueling. Obviously when its mapped on there, they put a correction factor in for this..
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline rio_gti
Re: bigger maf
« Reply #7 on: 06 October 2011, 11:28 »
to be perchasing a new maf then  :rolleyes:
Offline golf-sib
  • Турботазик
Re: bigger maf
« Reply #8 on: 06 October 2011, 19:21 »
I believe Dave is right, buy putting in a bigger MAF the reading will be offset causing the true reading to be incorrect
http://s4wiki.com/wiki/Mass_air_flow
« Last Edit: 06 October 2011, 19:45 by golf-sib »
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
