Author Topic: rear bumper bolts - siezed =(  (Read 2516 times)
Offline Cory
« on: 05 October 2011, 17:23 »
i found 1 bolt that i cant undo, and theres not alot of room to pay around with. socket is just turning and rounding off the bolt head. anyone had one stuck? id usually use mole grips or impact screwdriver but theres not alot of room under there!
Offline X4MGS
  • VAG Parts SNOB!!!
Re: rear bumper bolts - siezed =(
« Reply #1 on: 05 October 2011, 17:27 »
Yep Had this....
Heat it up and hammer on a smaller socket and use a Wrench Bar...
For More Info Click To See;
Offline Cory
« Reply #2 on: 05 October 2011, 17:34 »
havent got a blow torch or anything, would a penetrating liquid work?
Offline bodga
  • F reg GTI 16v
« Reply #3 on: 05 October 2011, 17:46 »
If you can see the thread  part of the bolt spray loads on then give it 10 mins or even go and have ya tea :wink:. After tea whack a socket on thats a bit tight with a hammer then it should come out. if you start undoing the bolt and its really tight, screw the bolt back in, spray with penetrating fluid again and try and remove the bolt
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #4 on: 05 October 2011, 18:35 »
I used one of these ever so handy just to have lying around....
http://www.ebay.co.uk/itm/Piezo-Self-Lighting-Butane-Blowtorch-Gas-Micro-Torch-BN-/280747432162?pt=UK_DIY_Materials_Plumbing_MJ&hash=item415dd9d8e2#ht_5175wt_1110
Got a better one now from the Mr's Kitchen  :shocked:
Offline pigbladder
« Reply #5 on: 05 October 2011, 21:08 »
irwin bolt grippers ...snap it if need be then deal with it once the bumper is off
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #6 on: 05 October 2011, 21:51 »
irwin bolt grippers
I Must Buy a set of these!!!
Offline Steve_B
« Reply #7 on: 05 October 2011, 22:04 »
Interesting. How hot would this get a bolt?
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #8 on: 05 October 2011, 22:07 »
Enough to free it - but you need serious arm muscles to hold it for the time required.... :laugh: :laugh: :laugh: :laugh:
Dont get me wrong it wont match a proper one or even a Gas Fitters one - but its better than nothing!!
Offline danny_p
« Reply #9 on: 05 October 2011, 23:42 »
http://www.ebay.co.uk/itm/Rothenberger-Super-Fire-2-Soldering-Torch-Mapp-Gas-/200436201608?pt=UK_DIY_Materials_Plumbing_MJ&hash=item2eaaedb888
there pritty damb good , ob vously a propper gas set is far better but they cost more and have bottel rental
all the VW's have gone bar 1.
