Author Topic: Cold Start Issue  (Read 1287 times)
Offline Wisey
Cold Start Issue
« on: 05 October 2011, 15:09 »
Been having this for a few months now and cant think what it could be   :undecided:
When you start it, when cold it will rev up to 1100ish rmp and sit there till it warms up abit, which is normal... But if you rev or drive the car, the rev will sit up at around 1500-1800ish rmp for a good few mins but its fine after its warmed up.
It only does if when starting from cold and the car hasn't been drove that day... And it also make the same kind of noise as a broken secondary air pump. but had a look and my car doesn't have one  :undecided:
Anyone got any ideas what it could be?  :rolleyes:
Oh and the engine is an AGU, 100% standard.
Offline richw911
Offline mcgee9t2
Re: Cold Start Issue
« Reply #2 on: 05 October 2011, 19:51 »
could it also possibly be the maf sensor?
thought tb clean is easier so ide defos give that a go first
Offline Wisey
« Reply #3 on: 05 October 2011, 22:32 »
Cheers, will give the TB a clean, its been on my list of things to do for a while  :sick:  :laugh:
Dont think it could be the maf, no lost of power etc at all. Just get the problem when the car hasn't been driving for 12+ hours
Offline mcgee9t2
« Reply #4 on: 05 October 2011, 22:43 »
hmm yeah does sound more likely. i know my revs are a bit weird atm (i.e when i turn it on it has high idle for a bit then bounces around before settling down) and thats due to a faulty maf. just havent got the money to change it atm.
Offline Scott D
« Reply #5 on: 05 October 2011, 23:55 »
could be coolant temp sensor or dirty TB - had similar problems when it had gone on mine.
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
