Author Topic: service now!  (Read 2596 times)
Offline Mr. Indecisive
  • Temporary userlolname.
service now!
« on: 03 October 2011, 21:31 »
So I serviced the ed30 yesterday and reset the service indicator with my vag com so it doesn't bing and flash up service now when started, thats all ok but when I hold in the 0.0 reset trip button and start the car I thought it was meant to now say 365 days or something like that ? It's still saying service now!  I've tried doing it with the vag-com and manually holding in the 0.0 reset button the the m button for the minutes but it's not reseting it, any ideas ??
Neal
5dr red ed30, parking sensors, xenons, winter pack, mfsw, sat nav, highline mfd, rear tints
Offline Ed30DSG
  • Edition 30 - gone - Audi S3 here
Re: service now!
« Reply #1 on: 04 October 2011, 09:00 »
Make sure the engine is turned off when you try either way.
For people without access to VAG-COM:
Vehicles with Multifunction Display -
1.) With the key out of the ignition – Press and hold the “0.0”, located on the right side of the instrument cluster.
2.) While holding the reset button insert the key and turn to the “Accessory” position. Wait for “Service now!” message to appear on multi–functionscreen.
3.) Then release the “0.0” and press the “m” (minutes) button on the opposite side of the instrument cluster.
4.) To verify it’s been reset hold the ”0.0″ button again – the display should indicate the future service by the message: “Service in 5,000 mi / 8,000 KM or 180 days or 10,000 mi / 16,000 km or 365 days” depending on Service Interval adaptation.
Vehicles without Multifunction Display -
2.) While holding the ”0.0″ button insert the key and turn to the “Accessory” position. Wait for “wrench” symbol to appear in the odometer display.
3.) Then release the “0.0” and press the “MIN” button on the opposite side of the instrument cluster.
4.) To verify it’s been reset hold the ”0.0″ button again: The “wrench” symbol will appear together with the reset number of miles / kilometers you can drive until the service due date. The display changes after about 10 seconds. A “clock” symbol appears together with the reset number of days until the service due date.
VAG-COM method:
1.) Select 17-Instruments
2.) Select Adaptation (10) under advanced functions
3.) Enter Adaptation Channel Number: 02 and select “Read”, The window should read: “Service Reminder” and ServRemInd Closed Reset
4.) Enter “00″ as the new value
5.) Select “Save” and select “Yes” when VAG-COM asks “Are you SURE?”
6.) To verify it’s been reset, with the key in the accessory position, hold the ”0.0″ button - the display should indicate the future service by the message: “Service in 5,000 mi / 8,000 KM or 180 days or 10,000 mi / 16,000 km or 365 days” depending on Service Interval adaptation.
« Last Edit: 04 October 2011, 09:11 by Ed30DSG »
Re: service now!
« Reply #2 on: 04 October 2011, 20:31 »
thanks for that but ive tried all of them but to no avail, as said the main service now light dosent come on when stating the car as it should,its just the days remaining i thought should be diplayed when holding the 0.0 buttton when starting the car, oh well, ill keep looking
neal
Offline Mr_F
Re: service now!
« Reply #3 on: 05 October 2011, 14:21 »
don't you have to wait for the car to calibrate again, so drive a few 100 miles or so?
61 Plate GTD 5dr, Shadow Blue, 18" Charleston's, Flat Tyre Indicator, Cruise Control, Bi-xenon (With Dynamic Curve), Storage Pack, Winter Pack and RCD 510.
Re: service now!
« Reply #4 on: 06 October 2011, 20:07 »
you might be right there ?  dont do many miles so might take a while but will leave it for now and try it again in a few week  :wink:
