Author Topic: k03s or not? -026  (Read 4124 times)
jamie16v
k03s or not? -026
« on: 03 October 2011, 19:09 »
have a good look at this listing.
i think this is not a k03s but a k03 as its an 026 not an 05x. tried telling the seller but he`s having none of it..  :tongue:
http://www.ebay.co.uk/itm/220866287666?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: k03s or not? -026
« Reply #1 on: 03 October 2011, 19:22 »
Quote
That turbo was build Until 2000Yand model  is Ko3-026, and is older version of Ko3-052/53 witch was build after 2000Y
It is 180BHP turbo witch also can replace 150BHP turbo and be remapped,
The bloke is talking out of his arse, the 026 has the smaller compressor housing. Just cos it was fitted to a 180bhp makes no odds
All the following turbos have the same installation dimensions and
thermodynamical performance. The differences are only in the actuator that
opens the turbine bypass valve:
K03-011 (5303 988 0011) 150 hp, 65 N actuator
K03-026 180 hp, 85 N actuator
K03-035 180 hp, 85 N actuator
K03-044 150 hp, 65 N actuator
K03-045 156 hp (Ibiza Cupra), 85 N actuator with 2 ports
K03-049 150 hp (Sharan/Alhambra), 65 N actuator
The 180 hp versions have an actuator with a higher opening force due to the
higher exhaust gas pressure (which is a consequence of the higher boost
pressure). Otherwise the valve would be pushed open by the exhaust gas
pressure.
The following turbos are a further development (since 2000) and have an
improved and slightly larger compressor while using the same turbine (still
with the same installation dimensions):
K03-052 180 hp, 85 N actuator
K03-053 150 hp, 85 N actuator
K03-058 150 hp/180 hp, 85 N actuator
jamie16v
« Reply #2 on: 03 October 2011, 19:27 »
it does appear to have a k03s tip but its still an 026 regardless  :tongue: oh, and the bids are reaeching over a 1`er.. some sorry numpty`s going to buy that one..
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 03 October 2011, 19:30 »
all depends what car it's off I spose.
Yeah it's not good, hope he gets caught out
jamie16v
« Reply #4 on: 03 October 2011, 19:31 »
what? you mean if its an "S" or not?. or if it has an alu TIP?.
Offline MaXXeH
  • Golf MK5 GTI
« Reply #5 on: 03 October 2011, 19:36 »
i got a k03s if anyone wants to buy one.  it is my last one.  done 47k
jamie16v
« Reply #6 on: 03 October 2011, 19:45 »
lol, i`m trying to prevent someone from buying a k03  :laugh:
jamie16v
« Reply #7 on: 03 October 2011, 21:40 »
seller still having none of it, don`t see why i really care but this guy is misrepresenting the turbo and i really do NOT like that at all.
i notice its a private bid.  :huh:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #8 on: 03 October 2011, 22:39 »
Ask him how many blades the compressor wheel has lol
jamie16v
« Reply #9 on: 04 October 2011, 10:21 »
mate, i honestly dont think he cares, i`m sure he is adimant that cos its a "k03-026" that it`s some form of early k03s..
his words were that the k03-052 and 053 are a modified k03-026 and that makes his 026 an "S"
here are his words from one of his replies to me. >>> ko3-52 or 52 are modified ko3-26 witch was build until 2000y, and ko3-52 or 53 was build after 2000y, and it is older version ko3s witch I also stated in advert. I`m not misguiding any one. thank you for your info.
- red-ream
« Last Edit: 04 October 2011, 10:24 by jamie16v »
