Author Topic: Dump valve  (Read 3610 times)
Offline PATEMANUK
Dump valve
« on: 30 September 2011, 20:16 »
Wanting to put a dump valve on my golf turbo has anyone had any problems or what is the best dump valve to get thanks
Offline boneybradley
  • Back in a Mk3...
Re: Dump valve
« Reply #1 on: 30 September 2011, 20:46 »
forge 007p are best (awesome do them for under £80)
If you don't want to spend that much, don't use a loud whoosh type as they cause running issues! only get a recirc type valve
Offline PATEMANUK
Re: Dump valve
« Reply #2 on: 30 September 2011, 20:57 »
K mate cheers thanks for the replay needed to ask as had people say that you can't really put dump valves on them thanks again
Offline PATEMANUK
Re: Dump valve
« Reply #3 on: 30 September 2011, 21:06 »
K mate car standard at the mo only had fir 2weeks first turbo lol thanks
Offline Dalo Harkin
Re: Dump valve
« Reply #4 on: 05 October 2011, 12:36 »
and fit it backwards if you want to hear it
I looked at this and apparently it can cause boost leaks
I fitted mine backwards and it instantly caused a boost leak, it also sounds like a chirp as opposed to a 'normal' DV noise
Offline daz veedub
  • Operation 1.8t bolf
Re: Dump valve
« Reply #5 on: 05 October 2011, 13:50 »
forge 007p from awesome gti.......nothing more nothing less  :wink: :smiley:
Offline lord14
Re: Dump valve
« Reply #6 on: 05 October 2011, 19:34 »
Are the standard 1.8t dumpvalves plastic ?
  • Back in a Mk3...
Re: Dump valve
« Reply #7 on: 05 October 2011, 20:07 »
yes and made by bosch
Re: Dump valve
« Reply #8 on: 05 October 2011, 21:57 »
Just bin the standard one and replace with a Forge 007 :smiley:
Offline Scott D
Re: Dump valve
« Reply #9 on: 06 October 2011, 00:28 »
forge 007 is the one to go for
however if your after dump valve sound you'll need an open cone / cai induction kit or drill some holes into the airbox.
or as suggested fit in reverse but I lost boost when trying this and it doesn't sound too good - makes a loud noise though  :grin:
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
