Author Topic: Bad misfire on agu  (Read 2901 times)
Offline yickergti
Bad misfire on agu
« on: 30 September 2011, 17:30 »
Hi all,my car has developed a bad misfire this morning and sounds like a small subaru. I drive the car home 10 mile fine from work with no problems,started to reverse it into the drive and it started to chug. I checked the coil packs 1 at a time and when i removed number 3 it made no difference so i though great,sussed it,easy fix,went and got a coil pack but its still doing it  :cry: Would plugs be the next thing to change? The car is a 1999 agu 1.8t
Any help would be appreciated  :smiley:
Offline The Doc
  • E63s Estate - Vito Sport
Re: Bad misfire on agu
« Reply #1 on: 30 September 2011, 18:04 »
Check your plugs yes or change plug 3 for plug 4 and see if your misfire moves  :wink:
Do you have access to vagcom?
Offline yickergti
« Reply #2 on: 30 September 2011, 18:17 »
Not got vagcom  :sad: just had another look and there is no spark at all on number 3
Offline MaXXeH
  • Golf MK5 GTI
« Reply #3 on: 30 September 2011, 18:20 »
it will be the ignition amp. 95% sure
Offline The Doc
« Reply #4 on: 30 September 2011, 18:36 »
Have you swapped the spark plug for a know good one and this is your conclusion?
Offline yickergti
« Reply #5 on: 30 September 2011, 18:44 »
Next door is a mechanic and he`s just done a quick test,said there is no spark but he cant have a proper look till monday. Was hoping to have a nosey down to santapod over the weekend aswell...doh
Offline The Doc
« Reply #6 on: 30 September 2011, 18:47 »
I feel for you mate, it's hard to guess from so far away  :sad:
Offline yickergti
« Reply #7 on: 30 September 2011, 19:55 »
I`ll give the ignition amp a clean tomorrow to see if it helps
Offline yickergti
« Reply #8 on: 30 September 2011, 19:59 »
The neighbor just said its the coil pack thats not sparking. Tested by putting a spare plug into the coil and running the engine
Offline MaXXeH
  • Golf MK5 GTI
« Reply #9 on: 30 September 2011, 20:15 »
i can bet u it will be the ignition amp, you cant clean them.
where are u based i have a spare one.
